43 class axlInspectorObjectManagerPrivate
   49     QString lastScalarFieldName;
   50     QString lastVectorFieldName;
   78     d->inspector_object->setController(d->controller);
   86     d->lastScalarFieldName =
   87     d->lastVectorFieldName =
  105     d->layout =
new QVBoxLayout(
this);
  106     d->layout->setAlignment(Qt::AlignTop);
  107     d->layout->setContentsMargins(0, 0, 0, 0);
  108     d->layout->setSpacing(0);
  109     d->layout->addWidget(d->tree);
  111     d->layout->addWidget(d->inspector_object);
  112     d->layout->addWidget(d->listSeparator);
  113     d->layout->addWidget(d->list);
  114     d->layout->addWidget(d->fieldSeparator);
  115     d->layout->addWidget(d->field);
  118     d->inspector_object->hide();
  119     d->listSeparator->hide();
  122     d->fieldSeparator->hide();
  127     connect(d->list, SIGNAL(currentItemChanged(QListWidgetItem *,QListWidgetItem *)),
this, SLOT(
onTransmitDataSelected(QListWidgetItem *,QListWidgetItem *)));
  130     connect(d->tree, SIGNAL(itemSelectionChanged()),
this, SLOT(onListSelectionChanged()));
  138     connect(d->tree, SIGNAL(
dataSetRemoved(QList<dtkAbstractData *>)), d->inspector_object, SLOT(onDataSetRemoved(QList<dtkAbstractData*>)));
  140     connect(d->tree, SIGNAL(selected(dtkAbstractData *)), d->inspector_object, SLOT(onDataSelected(dtkAbstractData *)));
  141     connect(d->tree, SIGNAL(dataSetSelected(QList<dtkAbstractData *>)), d->inspector_object, SLOT(onDataSetSelected(QList<dtkAbstractData *>)));
  142     connect(d->inspector_object, SIGNAL(
update()),
this, SIGNAL(
update()));
  143     connect(d->inspector_object, SIGNAL(
showCurrentPoint(
double,
double, dtkAbstractData *)),
this, SIGNAL(
showCurrentPoint(
double,
double, dtkAbstractData *)));
  144     connect(d->inspector_object, SIGNAL(
hideCurrentPoint(
double,
this, SIGNAL(
hideCurrentPoint(
double,
  145     connect(d->inspector_object, SIGNAL(
moveCurrentPoint(
double,
this, SIGNAL(
moveCurrentPoint(
double,
  167     return d->tree->insert(data);
  171     d->tree->remove(data);
  176     return d->tree->dataSet();
  181     for(
int i = 0; i < d->tree->columnCount(); i++)
  183         d->tree->resizeColumnToContents(i);
  189     d->tree->onStateChanged(data, mode);
  195     foreach(dtkAbstractData *data, dataToRemoved){
  196         if(dynamic_cast<axlAbstractVolumeDiscrete *>(data)){
  199                 d->layout->removeWidget(d->editor);
  205     d->tree->onDataRemoved(dataToRemoved);
  211     d->tree->removeAllItems();
  216     d->controller = controller;
  217     d->inspector_object->setController(controller);
  218     d->tree->setController(controller);
  222 void axlInspectorObjectManager::onListSelectionChanged(
void)
  224     if(d->tree->selectedItems().size() == 0 && d->controller)
  226         d->inspector_object->hide();
  228         d->listSeparator->hide();
  230         d->fieldSeparator->hide();
  233             d->layout->removeWidget(d->editor);
  243     if(d->tree->selectedItems().size() == 1 && d->controller)
  245         d->inspector_object->show();
  248         if(
axlAbstractData *axlData = dynamic_cast<axlAbstractData *>(d->controller->data(axlCurrentItem)))
  250             if(axlData->fields().count() != 0)
  253                 d->listSeparator->show();
  257             if(dynamic_cast<axlAbstractVolumeDiscrete *>(axlData)){
  259                 d->layout->addWidget(d->editor);
  260                 d->editor->setView(d->view);
  261                 d->editor->setData(axlData);
  266                     d->layout->removeWidget(d->editor);
  274             d->list->setData(axlData);
  335             for (
int i = 0 ; i < d->controller->items().size() ; i++)
  339                 if(axldata->
fields().size() > 0){
  340                     d->list->setData(axldata);
  345                     for (
int i = 0 ; i < d->list->count() ; i++)
  347                         QListWidgetItem *listItem = d->list->item(i);
  348                         if(dynamic_cast<axlInspectorObjectManagerListItem *>(listItem)->field()->kind() ==
axlAbstractField::Scalar && dynamic_cast<axlInspectorObjectManagerListItem *>(listItem)->field()->kind() == dynamic_cast<axlInspectorObjectManagerListItem *>(d->list->item(d->list->count() - 1))->field()->kind())
  349                             dynamic_cast<axlAbstractActorField *>(d->view->actor(dynamic_cast<axlInspectorObjectManagerListItem *>(listItem)->field()))->displayAsNoneScalar();
  351                         if( dynamic_cast<axlInspectorObjectManagerListItem *>(listItem)->field()->kind() ==
axlAbstractField::Vector  && dynamic_cast<axlInspectorObjectManagerListItem *>(listItem)->field()->kind() == dynamic_cast<axlInspectorObjectManagerListItem *>(d->list->item(d->list->count() - 1))->field()->kind())
  361             this->onListSelectionChanged();
  367             d->field->setField(field);
  374                 d->lastScalarFieldName = field->name();
  382                 d->lastVectorFieldName = field->name();
  388             if ( dynamic_cast<axlAbstractActorField *>(d->view->actor(field)) )
  396         qDebug() <<
"axlInspectorObjectManager::onTransmitDataSelected" <<
"error";
  404     if(d->list->selectedItems().isEmpty())
  407         d->fieldSeparator->hide();
  413         d->fieldSeparator->show();
  439     for (
  443         if(axldata->
  444             d->list->setData(axldata);
  449             for (
  451                 QListWidgetItem *listItem = d->list->item(i);
  452                 if(dynamic_cast<axlInspectorObjectManagerListItem *>(listItem)->field()->kind() ==
  453                     dynamic_cast<axlAbstractActorField *>(d->view->actor(dynamic_cast<axlInspectorObjectManagerListItem *>(listItem)->field()))->displayAsNoneScalar();
  455                 if( dynamic_cast<axlInspectorObjectManagerListItem *>(listItem)->field()->kind() ==
  472             if(currentField->name() == fieldName)
  473                 field = currentField;
  482                     dynamic_cast<axlAbstractActorField *>(d->view->actor(currentField))->displayAsNoneScalar();
  484                     dynamic_cast<axlAbstractActorField *>(d->view->actor(currentField))->displayAsNoneVector();
  490                 dynamic_cast<axlAbstractActorField *>(d->view->actor(field))->displayAsColor();
  492                 dynamic_cast<axlAbstractActorField *>(d->view->actor(field))->displayAsGlyph();
  502     if(d->tree->selectedItems().size() > 1 )
  509                 if(currentField->name() == fieldName)
  510                     field = currentField;
  518                         dynamic_cast<axlAbstractActorField *>(d->view->actor(currentField))->displayAsNoneScalar();
  520                         dynamic_cast<axlAbstractActorField *>(d->view->actor(currentField))->displayAsNoneVector();
  526                     dynamic_cast<axlAbstractActorField *>(d->view->actor(field))->displayAsColor();
  528                     dynamic_cast<axlAbstractActorField *>(d->view->actor(field))->displayAsGlyph();
  540         for (
  544             if(axldata->
  545                 d->list->setData(axldata);
  549                 for (
  551                     QListWidgetItem *listItem = d->list->item(i);
  552                     if(dynamic_cast<axlInspectorObjectManagerListItem *>(listItem)->field()->kind() ==
  553                         dynamic_cast<axlAbstractActorField *>(d->view->actor(dynamic_cast<axlInspectorObjectManagerListItem *>(listItem)->field()))->displayAsNoneScalar();
  555                     if( dynamic_cast<axlInspectorObjectManagerListItem *>(listItem)->field()->kind() ==
  568         d->list->setData(dataList.last());
  577                 d->field->setField(field);
  583                 d->fieldSeparator->show();
  589                     d->lastScalarFieldName = field->name();
  597                     d->lastVectorFieldName = field->name();
  640     d->field->setView(view);
  647     connect(d->inspector_object, SIGNAL(tubeFilterRadiusChanged(dtkAbstractData *,
double)), d->view, SLOT(onTubeFilterRadiusChanged(dtkAbstractData *,
double)));
axlInspectorObjectManagerTreeItem * insert(axlAbstractData *data)
void modifiedProperty(dtkAbstractData *, int)
void actorVisibilityChanged(dtkAbstractData *data, bool actorVisibility)
QList< dtkAbstractData * > dataSet(void)
axlAbstractField * onTransmitDataSelected(QListWidgetItem *fromItem, QListWidgetItem *toItem)
void removeData(dtkAbstractData *data)
void onDataRemoved(QList< dtkAbstractData * > dataToRemoved)
void setController(axlInspectorObjectController *controller)
void interpolationChanded(dtkAbstractData *data, int interpolation)
void onStateChanged(dtkAbstractData *data, int mode)
void dataChangedByGeometry(dtkAbstractData *data)
virtual void displayAsNoneVector(void)
void onFieldsCreatedOnData(QList< axlAbstractData * > dataList, QString fieldName)
void resizeColumnToContents()
void onFieldOpened(QList< axlAbstractData * > dataList, QString fieldName)
void dataSetRemoved(QList< dtkAbstractData * > dataSetRemoved)
void showCurrentPoint(double u, double v, dtkAbstractData *data)
void setView(axlAbstractView *view)
axlInspectorObjectManager(QWidget *parent=0)
Class axlAbstractField defines an API for arrays of numeric data.
void stateChanged(dtkAbstractData *data, int mode)
~axlInspectorObjectManager(void)
virtual void displayAsColor(void)
QList< axlAbstractField * > fields(void)
void hideCurrentPoint(double u, double v, dtkAbstractData *data)
void moveCurrentPoint(double u, double v, dtkAbstractData *data)
void onFieldListSelectionChanged(void)
Class axlAbstractData defines an API for all type of axel data.
virtual void displayAsGlyph(void)
