14 #include "axlCoreExport.h"
   15 #ifndef AXLFIELDPARAMETRICVOLUMETANGENTVECTOR_H
   16 #define AXLFIELDPARAMETRICVOLUMETANGENTVECTOR_H
   20 class axlFieldParametricVolumeTangentVectorPrivate;
   32     void setParameter(
double parameter,
int channel);
   34     double parameter(
int channel);
   51     double *
vector(
double u,
double v,
double w);
   63     axlFieldParametricVolumeTangentVectorPrivate *d;
   69 #endif // AXLFIELDPARAMETRICVOLUMETANGENTVECTOR_H
virtual void setVolume(axlAbstractData *Volume)
Sets the support Volume of the field.
virtual double start_u(void)
Returns the first u-value parameter.
virtual double end_u(void)
Returns the last u-value parameter.
virtual double numbersample_u(void)
Returns the number of u-parameters.
virtual double numbersample_v(void)
Returns the number of v-parameters.
virtual double start_v(void)
Returns the first v-value parameter.
virtual double end_w(void)
Returns the last w-value parameter.
virtual QString description(void) const
Returns the description of the field.
virtual double * vector(double u, double v, double w)
Returns the value of the parametric field evaluated at the parameters in input.
virtual double end_v(void)
Returns the last v-value parameter.
virtual void update(void)
virtual double numbersample_w(void)
Returns the number of w-parameters.
Class axlAbstractFieldParametricVolume defines an API for parametric field.
virtual QString identifier(void) const
virtual int size(void)
Returns number of parameters on which the field is evaluated.
AXLCORE_EXPORT dtkAbstractData * createaxlFieldParametricVolumeTangentVector(void)
virtual double start_w(void)
Returns the first w-value parameter.
Class axlAbstractData defines an API for all type of axel data.
Class axlFieldParametricVolumeTangentVector defines an API for field which owns a BSpline Surface as ...
