Go to the source code of this file.
Classes | |
| class | axlFieldParametricVolumeTangentVector |
| Class axlFieldParametricVolumeTangentVector defines an API for field which owns a BSpline Surface as a function and a parametric surface on which the field is applied. More... | |
Functions | |
| AXLCORE_EXPORT dtkAbstractData * | createaxlFieldParametricVolumeTangentVector (void) |
| AXLCORE_EXPORT dtkAbstractData* createaxlFieldParametricVolumeTangentVector | ( | void | ) |
Definition at line 310 of file axlFieldParametricVolumeTangentVector.cpp.
