21 #include <dtkCoreSupport/dtkAbstractData.h>
22 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
23 #include <dtkCoreSupport/dtkAbstractProcessFactory.h>
41 return "axlFieldParametricVolumeReader";
46 return "axlFieldParametricVolumeReader";
51 return QStringList() <<
"axlFieldParametricVolume";
61 QDomElement element = node.toElement();
63 if(element.tagName() !=
"field")
71 return !this->
accept(node);
79 dtkWarn() << Q_FUNC_INFO <<
"enter";
80 QDomElement element = node.toElement();
84 QString type = element.attribute(
"type");
91 QString name = element.attribute(
"name");
94 field->setObjectName(name);
98 QString typeField = element.attribute(
"valueType");
99 if(!typeField.isEmpty()){
100 if(typeField ==
"int"){
102 }
else if(typeField ==
"float"){
111 QString support = element.attribute(
"support");
112 if(support ==
"point"){
114 }
else if(support ==
"cell"){
121 QString kind = element.attribute(
"kind");
122 if(kind ==
"scalar"){
124 }
else if(kind ==
"vector"){
132 QDomNodeList listFunction = element.elementsByTagName(
"volume");
133 QDomElement functionDescription = listFunction.at(0).toElement();
135 dtkAbstractData *data = NULL;
137 foreach(QString reader, dtkAbstractDataFactory::instance()->readers()) {
139 data = this->
dataByReader(axl_reader, functionDescription);
160 if(!axl_reader->
accept(node))
163 axl_reader->dtkAbstractDataReader::read(this->file());
165 if(dtkAbstractData *data = axl_reader->
read(node))
~axlFieldParametricVolumeReader(void)
dtkAbstractDataReader * createaxlFieldParametricVolumeReader(void)
void setFunction(axlAbstractData *data)
Sets the Bspline function which determines the values of the parametric field.
virtual axlAbstractData * read(const QDomNode &node)=0
virtual void update(void)
bool accept(const QDomNode &node)
virtual void setType(Type type)
Sets the type of the field which can be either int, float or double.
QString description(void) const
static bool registered(void)
QString identifier(void) const
bool reject(const QDomNode &node)
virtual void setSupport(Support support)
virtual bool accept(const QDomNode &node)=0
QStringList handled(void) const
Class axlFieldParametricVolume defines an API for field which owns a BSpline Volume.
dtkAbstractData * dataByReader(axlAbstractDataReader *axl_reader, const QDomNode &node)
virtual void setKind(Kind kind)
Sets the kind of the field which can be either scalar, vector or tensor.
Class axlAbstractData defines an API for all type of axel data.
