18 #include <dtkCoreSupport/dtkAbstractProcessFactory.h>
   24 class axlEllipsoidCreatorPrivate{
   60     }
else if(channel == 1){
   63     else if(channel == 2){
   74         d->output =
dynamic_cast<axlEllipsoid *
>(process->output());
   89     if(dynamic_cast<axlPoint *>(newData)){
   93         }
   96         else if(channel == 2){
  109     if(d->output == NULL){
  110         if(d->point1 && d->point2 && d->point3 && d->point4){
  112             d->output = newEllipsoid;
  118         if(d->point1 && d->point2 && d->point3 && d->point4){
  119             d->output->setValues(d->point1, d->point2, d->point3, d->point4);
  130     return "create a ellipsoid with four points : \n the first one is the center, \n the three others determine its 3 axes";
  135     return "axlEllipsoidCreator";
Class axlPoint defines 3D points.
virtual ~axlEllipsoidCreator(void)
virtual QString description(void) const
virtual QString identifier(void) const
static bool registered(void)
virtual axlAbstractData * getInput(int channel) const
void copyProcess(axlAbstractProcess *process)
virtual dtkAbstractData * output(void)
dtkAbstractProcess * createaxlEllipsoidCreator(void)
virtual void setInput(dtkAbstractData *newData, int channel)
Class axlEllipsoid defines 3D ellipsoids.
axlEllipsoidCreator(QObject *parent=0)
Class axlAbstractData defines an API for all type of axel data.
