#include <axlEllipsoidCreator.h>
 Public Member Functions | |
| axlEllipsoidCreator (QObject *parent=0) | |
| virtual | ~axlEllipsoidCreator (void) |
| virtual axlAbstractData * | getInput (int channel) const |
| void | copyProcess (axlAbstractProcess *process) |
| bool | hasParameters (void) |
| virtual int | update (void) |
| virtual QString | description (void) const |
| virtual QString | identifier (void) const |
| virtual void | setInput (dtkAbstractData *newData, int channel) |
| virtual dtkAbstractData * | output (void) |
  Public Member Functions inherited from axlAbstractCreatorProcess | |
| axlAbstractCreatorProcess (QObject *parent=0) | |
| virtual | ~axlAbstractCreatorProcess (void) |
| virtual dtkAbstractData * | output (int channel) |
| virtual int | channelCount (void) |
  Public Member Functions inherited from axlAbstractProcess | |
| axlAbstractProcess (void) | |
| virtual | ~axlAbstractProcess (void) |
| virtual void | setDescription (QString description) |
| virtual void | setIdentifier (QString identifier) |
| virtual QString | form (void) const |
| Description of the form for the dialog with the process.  More... | |
Static Public Member Functions | |
| static bool | registered (void) |
Definition at line 29 of file axlEllipsoidCreator.h.
| axlEllipsoidCreator::axlEllipsoidCreator | ( | QObject * | parent = 0 | ) |
Definition at line 39 of file axlEllipsoidCreator.cpp.
  virtual |
Definition at line 50 of file axlEllipsoidCreator.cpp.
  virtual |
Reimplemented from axlAbstractProcess.
Definition at line 72 of file axlEllipsoidCreator.cpp.
  virtual |
Reimplemented from axlAbstractCreatorProcess.
Definition at line 129 of file axlEllipsoidCreator.cpp.
  virtual |
Definition at line 57 of file axlEllipsoidCreator.cpp.
  virtual |
returns true if the process needs parameters. By default, equals false.
Definition at line 78 of file axlEllipsoidCreator.cpp.
  virtual |
Definition at line 134 of file axlEllipsoidCreator.cpp.
  virtual |
Definition at line 83 of file axlEllipsoidCreator.cpp.
  static |
Definition at line 139 of file axlEllipsoidCreator.cpp.
  virtual |
Definition at line 88 of file axlEllipsoidCreator.cpp.
  virtual |
Definition at line 107 of file axlEllipsoidCreator.cpp.
