#include <axlVtkView.h>
Public Slots | |
| void | onShowAxis (bool show) |
| void | onGridResolutionChanged (int resolution) |
| void | setBackgroundColor (double red, double green, double blue) |
| void | onBackgroundGradientChange (bool gradient) |
| void | setWorldCamera (void) |
| void | setObjectCamera (void) |
| void | setTrackballInteractor (void) |
| void | setJoystickInteractor (void) |
| void | onUpdateActorField (QList< axlAbstractData * > axlDataSet, QString fieldName) |
| void | bounds (float &xmin, float &xmax, float &ymin, float &ymax, float &zmin, float &zmax) |
| void | cameraUp (double *coordinates) |
| void | cameraPosition (double *coordinates) |
| void | cameraFocalPoint (double *coordinates) |
| void | setCameraPosition (double x, double y, double z) |
Public Slots inherited from axlAbstractView | |
| void | onStateChanged (dtkAbstractData *data, int mode) |
| void | showColorMapping (dtkAbstractData *data) |
| void | onShaderChanged (dtkAbstractData *data, QString isophoteShaderXml) |
| void | onControlPointChanged (dtkAbstractData *data) |
| void | onTubeFilterRadiusChanged (dtkAbstractData *data, double radius) |
| void | processIsophoteByShader (dtkAbstractData *data, QString isophoteShaderXml) |
| void | dataChangedByGeometry (dtkAbstractData *data) |
| void | dataChangedByProperty (dtkAbstractData *data, int channel) |
| Modify the right property, which is defined by the channel number : More... | |
| void | dataChangedByOpacity (dtkAbstractData *data, double opacity) |
| void | dataChangedBySize (dtkAbstractData *data, double size) |
| void | dataChangedByColor (dtkAbstractData *data, double red, double green, double blue) |
| void | onActorVisibilityChanged (dtkAbstractData *data, bool actorVisibility) |
| void | ondataSetRemoved (QList< dtkAbstractData * > dataSetToRemoved) |
| void | onLightPositionChanged (double x, double y, double z) |
| virtual void | onUpdateActorField (QList< axlAbstractData * > axlDataSet, QString fieldName) |
| void | onInterpolationChanded (dtkAbstractData *data, int interpolation) |
| virtual void | onShowAxis (bool show) |
| virtual void | onBackgroundGradientChange (bool gradient) |
| virtual void | setWorldCamera (void) |
| virtual void | setObjectCamera (void) |
| virtual void | setTrackballInteractor (void) |
| virtual void | setJoystickInteractor (void) |
Public Member Functions | |
| axlVtkView (void) | |
| virtual | ~axlVtkView (void) |
| virtual QString | description (void) const |
| axlAbstractActor * | insert (axlAbstractData *data) |
| QList< axlAbstractActor * > | insertSet (QList< axlAbstractData * > dataSet) |
| void | removeSet (QList< axlAbstractActor * > actorSet) |
| void | removeSetFields (QList< axlAbstractActorField * > actorSet) |
| void | update (void) |
| void | activeDefaultLigh (bool useDefaultLight) |
| void | setLight (int i, bool hide, double *position, double *ambiant, double *diffuse, double *specular, int exponent) |
| void | setCameraViewDefaut (void) |
| void | setCameraViewNegativeX (void) |
| void | setCameraViewPositiveX (void) |
| void | setCameraViewNegativeY (void) |
| void | setCameraViewPositiveY (void) |
| void | setCameraViewNegativeZ (void) |
| void | setCameraViewPositiveZ (void) |
| void | setParallelCamera (bool parallel) |
| void | setCameraFocalPoint (double x, double y, double z) |
| void | setCameraUp (double x, double y, double z) |
| void | setCameraViewAngle (double angle) |
| void | setParallelScale (double parallelScale) |
| void | setGrid (bool isGridX, bool isGridY, bool isGridZ) |
| double * | getWorldCameraPosition (void) |
| double * | getBackgroundColor (void) |
| bool | getAxesVisibility (void) |
| bool | getParallelProjection (void) |
| double * | getCameraFocalPoint (void) |
| double * | getCameraUp (void) |
| double | getCameraViewAngle (void) |
| bool | getBackgroundGradient (void) |
| double | getParallelScale (void) |
| QWidget * | widget (void) |
| void | updateFieldActor (dtkAbstractData *data) |
| Use view as input to update fields actors on a data. More... | |
Public Member Functions inherited from axlAbstractView | |
| axlAbstractView (void) | |
| virtual | ~axlAbstractView (void) |
| virtual axlAbstractActor * | actor (dtkAbstractData *data) |
| virtual void | insert (dtkAbstractData *data, axlAbstractActor *actor) |
| virtual void | removeData (dtkAbstractData *data) |
| virtual void | removeField (dtkAbstractData *data) |
| virtual int | size (void) |
| axlViewController * | controller (void) |
| virtual void | setCameraPosition (double x, double y, double z) |
| dtkAbstractViewFactory * | getSingletonFactory (void) |
| virtual void | add (dtkAbstractData *data) |
| Use view as input to open a data in axel. More... | |
Static Public Member Functions | |
| static bool | registered (void) |
Additional Inherited Members | |
Signals inherited from axlAbstractView | |
| void | inserted (void) |
| void | stateChanged (dtkAbstractData *data, int mode) |
| void | lightPositionChanged (double x, double y, double z) |
| void | insertData (axlAbstractData *data) |
Definition at line 38 of file axlVtkView.h.
| axlVtkView::axlVtkView | ( | void | ) |
Definition at line 312 of file axlVtkView.cpp.
virtual |
Definition at line 410 of file axlVtkView.cpp.
virtual |
Reimplemented from axlAbstractView.
Definition at line 1436 of file axlVtkView.cpp.
slot |
Definition at line 483 of file axlVtkView.cpp.
slot |
Definition at line 509 of file axlVtkView.cpp.
slot |
Definition at line 502 of file axlVtkView.cpp.
slot |
Definition at line 495 of file axlVtkView.cpp.
virtual |
Definition at line 442 of file axlVtkView.cpp.
virtual |
Definition at line 1353 of file axlVtkView.cpp.
virtual |
Definition at line 1385 of file axlVtkView.cpp.
virtual |
Definition at line 1345 of file axlVtkView.cpp.
virtual |
Definition at line 1361 of file axlVtkView.cpp.
virtual |
Definition at line 1369 of file axlVtkView.cpp.
virtual |
Definition at line 1377 of file axlVtkView.cpp.
virtual |
Definition at line 1357 of file axlVtkView.cpp.
virtual |
Definition at line 1341 of file axlVtkView.cpp.
virtual |
Definition at line 1349 of file axlVtkView.cpp.
virtual |
Definition at line 969 of file axlVtkView.cpp.
virtual |
Definition at line 525 of file axlVtkView.cpp.
slot |
Definition at line 1330 of file axlVtkView.cpp.
slot |
Definition at line 2011 of file axlVtkView.cpp.
slot |
Definition at line 2027 of file axlVtkView.cpp.
slot |
Definition at line 2060 of file axlVtkView.cpp.
static |
Definition at line 436 of file axlVtkView.cpp.
virtual |
Definition at line 912 of file axlVtkView.cpp.
virtual |
Definition at line 854 of file axlVtkView.cpp.
slot |
Definition at line 1389 of file axlVtkView.cpp.
virtual |
Definition at line 1365 of file axlVtkView.cpp.
slot |
Definition at line 516 of file axlVtkView.cpp.
virtual |
Definition at line 1373 of file axlVtkView.cpp.
virtual |
Definition at line 1381 of file axlVtkView.cpp.
virtual |
Definition at line 1568 of file axlVtkView.cpp.
virtual |
Definition at line 1584 of file axlVtkView.cpp.
virtual |
Definition at line 1646 of file axlVtkView.cpp.
virtual |
Definition at line 1708 of file axlVtkView.cpp.
virtual |
Definition at line 1615 of file axlVtkView.cpp.
virtual |
Definition at line 1677 of file axlVtkView.cpp.
virtual |
Definition at line 1739 of file axlVtkView.cpp.
virtual |
Definition at line 1770 of file axlVtkView.cpp.
slot |
Definition at line 474 of file axlVtkView.cpp.
virtual |
Definition at line 1548 of file axlVtkView.cpp.
slot |
Definition at line 456 of file axlVtkView.cpp.
virtual |
Definition at line 2035 of file axlVtkView.cpp.
virtual |
Definition at line 1337 of file axlVtkView.cpp.
slot |
Definition at line 465 of file axlVtkView.cpp.
slot |
Definition at line 447 of file axlVtkView.cpp.
virtual |
Definition at line 2045 of file axlVtkView.cpp.
virtual |
Usefull with interpreter
Definition at line 2207 of file axlVtkView.cpp.
| QWidget * axlVtkView::widget | ( | void | ) |
Definition at line 2051 of file axlVtkView.cpp.
