#include <axlPointSet.h>
Public Member Functions | |
| axlPointSet (void) | |
| virtual | ~axlPointSet (void) |
| Virtual destructor, enables safe inheritance. More... | |
| virtual QString | description (void) const |
| virtual QString | identifier (void) const |
| QString | objectType (void) const |
| bool | isPlanar (void) const |
| void | setPlanar (const bool isPlanar) |
| bool | isUniqueColor (void) const |
| void | setUniqueColor (const bool uniqueColor) |
| int | numberOfPoints (void) const |
| void | push_front (axlPoint *p) |
| void | push_back (axlPoint *p) |
| QDebug | printAxlAbstractPoints (QDebug dbg) |
| void | printAxlPointSet (void) |
| void * | points (void) const |
| void * | points (void) |
| axlPoint * | value (int n) const |
| axlPoint * | value (int n) |
Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object. More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object. More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed. More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object. More... | |
| virtual QVariantList | convertDataToQVariant (void) const |
| Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
| virtual int | convertQVariantToData (const QVariantList &data) |
| Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
Static Public Member Functions | |
| static bool | registered (void) |
Additional Inherited Members | |
Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
Definition at line 29 of file axlPointSet.h.
| axlPointSet::axlPointSet | ( | void | ) |
Definition at line 40 of file axlPointSet.cpp.
virtual |
Definition at line 47 of file axlPointSet.cpp.
virtual |
Definition at line 140 of file axlPointSet.cpp.
virtual |
Definition at line 147 of file axlPointSet.cpp.
| bool axlPointSet::isPlanar | ( | void | ) | const |
Definition at line 65 of file axlPointSet.cpp.
| bool axlPointSet::isUniqueColor | ( | void | ) | const |
Definition at line 75 of file axlPointSet.cpp.
| int axlPointSet::numberOfPoints | ( | void | ) | const |
Definition at line 85 of file axlPointSet.cpp.
| QString axlPointSet::objectType | ( | void | ) | const |
Definition at line 152 of file axlPointSet.cpp.
| void * axlPointSet::points | ( | void | ) | const |
Definition at line 55 of file axlPointSet.cpp.
Definition at line 60 of file axlPointSet.cpp.
| QDebug axlPointSet::printAxlAbstractPoints | ( | QDebug | dbg | ) |
Definition at line 117 of file axlPointSet.cpp.
| void axlPointSet::printAxlPointSet | ( | void | ) |
Definition at line 129 of file axlPointSet.cpp.
| void axlPointSet::push_back | ( | axlPoint * | p | ) |
Definition at line 98 of file axlPointSet.cpp.
| void axlPointSet::push_front | ( | axlPoint * | p | ) |
Definition at line 91 of file axlPointSet.cpp.
static |
Definition at line 134 of file axlPointSet.cpp.
| void axlPointSet::setPlanar | ( | const bool | isPlanar | ) |
Definition at line 70 of file axlPointSet.cpp.
| void axlPointSet::setUniqueColor | ( | const bool | uniqueColor | ) |
Definition at line 80 of file axlPointSet.cpp.
| axlPoint * axlPointSet::value | ( | int | n | ) | const |
Definition at line 104 of file axlPointSet.cpp.
Definition at line 110 of file axlPointSet.cpp.
