#include <axlInspectorObjectComposite.h>
| axlInspectorObjectComposite::axlInspectorObjectComposite |
QWidget * |
parent = 0 | ) |
| axlInspectorObjectComposite::~axlInspectorObjectComposite |
void |
| void axlInspectorObjectComposite::hideCurrentPoint |
double |
u, |
double |
v, |
dtkAbstractData * |
data |
signal |
| void axlInspectorObjectComposite::modifiedProperty |
dtkAbstractData * |
int |
signal |
| void axlInspectorObjectComposite::moveCurrentPoint |
double |
u, |
double |
v, |
dtkAbstractData * |
data |
signal |
| void axlInspectorObjectComposite::onColorChanged |
QColor |
color | ) |
slot |
| void axlInspectorObjectComposite::onHideCurrentPoint |
double |
u, |
double |
v |
slot |
| void axlInspectorObjectComposite::onLineEditShaderChanged |
QString |
shader | ) |
slot |
| void axlInspectorObjectComposite::onMoveCurrentPoint |
double |
u, |
double |
v |
slot |
| void axlInspectorObjectComposite::onOpacityChanged |
int |
opacity | ) |
slot |
| void axlInspectorObjectComposite::onShaderChanged |
QString |
shader | ) |
slot |
| void axlInspectorObjectComposite::onShaderStateChanged |
bool |
isShader | ) |
slot |
| void axlInspectorObjectComposite::onShowCurrentPoint |
double |
u, |
double |
v |
slot |
| void axlInspectorObjectComposite::openShader |
void |
slot |
| void axlInspectorObjectComposite::showCurrentPoint |
double |
u, |
double |
v, |
dtkAbstractData * |
data |
signal |
| QSize axlInspectorObjectComposite::sizeHint |
void |
const |
| void axlInspectorObjectComposite::update |
void |
signal |
The documentation for this class was generated from the following files:
