#include <axlAbstractDataComposite.h>
 Signals | |
| void | updated (void) |
| void | samplingChanged () |
  Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
Public Member Functions | |
| axlAbstractDataComposite (void) | |
| virtual | ~axlAbstractDataComposite (void) |
| void | add (dtkAbstractData *data) |
| bool | get (dtkAbstractData *data) |
| void | set (QList< dtkAbstractData * > data) |
| void | remove (dtkAbstractData *data) |
| int | count (void) |
| dtkAbstractData * | get (int i) |
| virtual QString | description (void) const |
| virtual QString | identifier (void) const |
  Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object.  More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object.  More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed.  More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object.  More... | |
| virtual QVariantList | convertDataToQVariant (void) const |
| Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData.  More... | |
| virtual int | convertQVariantToData (const QVariantList &data) |
| Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0.  More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
Additional Inherited Members | |
  Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
  Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
Definition at line 31 of file axlAbstractDataComposite.h.
| axlAbstractDataComposite::axlAbstractDataComposite | ( | void | ) |
Definition at line 31 of file axlAbstractDataComposite.cpp.
  virtual |
Definition at line 39 of file axlAbstractDataComposite.cpp.
| void axlAbstractDataComposite::add | ( | dtkAbstractData * | data | ) |
Definition at line 46 of file axlAbstractDataComposite.cpp.
| int axlAbstractDataComposite::count | ( | void | ) |
Definition at line 68 of file axlAbstractDataComposite.cpp.
  virtual |
Reimplemented in axlDataDynamic.
Definition at line 78 of file axlAbstractDataComposite.cpp.
| bool axlAbstractDataComposite::get | ( | dtkAbstractData * | data | ) |
Definition at line 51 of file axlAbstractDataComposite.cpp.
| dtkAbstractData * axlAbstractDataComposite::get | ( | int | i | ) |
Definition at line 73 of file axlAbstractDataComposite.cpp.
  virtual |
Definition at line 83 of file axlAbstractDataComposite.cpp.
| void axlAbstractDataComposite::remove | ( | dtkAbstractData * | data | ) |
Definition at line 63 of file axlAbstractDataComposite.cpp.
  signal |
| void axlAbstractDataComposite::set | ( | QList< dtkAbstractData * > | data | ) |
Definition at line 57 of file axlAbstractDataComposite.cpp.
  signal |
