24 #include <dtkCoreSupport/dtkAbstractData.h>
   26 #include <dtkGuiSupport/dtkColorButton.h>
   27 #include <dtkGuiSupport/dtkSplitter.h>
   33 class axlInspectorObjectCompositePrivate
   37     dtkColorButton *colorButton;
   39     QComboBox *comboBoxShader;
   41     QCheckBox *checkBoxShader;
   42     QLineEdit *lineEditShader;
   43     QPushButton *buttonShader;
   45     QSlider *sliderOpacity;
   57     d->sliderOpacity =
new QSlider(Qt::Horizontal,
this);
   58     d->sliderOpacity->setMaximum(100);
   60     d->comboBoxShader  =
new QComboBox(
this);
   62     d->checkBoxShader =
new QCheckBox(
this);
   63     d->lineEditShader =
new QLineEdit(
this);
   64     d->buttonShader =
new QPushButton(
this);
   65     d->buttonShader->setText(
"open");
   66     d->lineEditShader->setEnabled(
false);
   67     d->buttonShader->setEnabled(
false);
   68     d->comboBoxShader->setEnabled(
false);
   70     d->colorButton =
new dtkColorButton(
this);
   72     QHBoxLayout *layoutColorButton =
new QHBoxLayout;
   73     layoutColorButton->addWidget(
new QLabel(
"Color",
this));
   74     layoutColorButton->addWidget(d->colorButton);
   76     QHBoxLayout *layoutOpacity =
new QHBoxLayout;
   77     layoutOpacity->addWidget(
new QLabel(
"Opacity",
this));
   78     layoutOpacity->addWidget(d->sliderOpacity);
   80     QVBoxLayout *layoutShader =
new QVBoxLayout;
   81     QHBoxLayout *layoutShader1 =
new QHBoxLayout;
   82     QLabel *labelShader  =
new QLabel(
"Shader",
this);
   83     layoutShader1->addWidget(labelShader);
   84     layoutShader1->addWidget(d->checkBoxShader);
   85     layoutShader1->addWidget(d->comboBoxShader);
   86     layoutShader1->addWidget(d->buttonShader);
   87     layoutShader1->setStretchFactor(labelShader, 2);
   88     layoutShader1->setStretchFactor(d->checkBoxShader, 1);
   89     layoutShader1->setStretchFactor(d->comboBoxShader, 4);
   90     layoutShader1->setStretchFactor(d->buttonShader, 3);
   92     layoutShader->addLayout(layoutShader1);
   93     layoutShader->addWidget(d->lineEditShader);
   95     QVBoxLayout *layoutTop =
new QVBoxLayout;
   96     layoutTop->addWidget(
new QLabel(
"axlInspectorObjectComposite",
this));
   97     layoutTop->addLayout(layoutColorButton);
   98     layoutTop->addLayout(layoutOpacity);
   99     layoutTop->addLayout(layoutShader);
  100     layoutTop->addStretch(1);
  102     QWidget *top =
new QWidget(
this);
  103     top->setMaximumWidth(295);
  104     top->setLayout(layoutTop);
  106     dtkSplitter *splitter =
new dtkSplitter(
this,
true);
  107     splitter->setOrientation(Qt::Vertical);
  108     splitter->addWidget(top);
  109     splitter->addWidget(d->parameter_space);
  111     QVBoxLayout *layout =
new QVBoxLayout(
this);
  112     layout->setContentsMargins(0, 0, 0, 0);
  113     layout->setSpacing(0);
  114     layout->addWidget(splitter);
  118     connect(d->buttonShader, SIGNAL(clicked()),
this, SLOT(
openShader()));
  124     connect(d->parameter_space, SIGNAL(
update()),
this, SIGNAL(
update()));
  136     return QSize(300, 300);
  144     QColor color =
object->color();
  146     d->colorButton->setColor(color);
  147     d->sliderOpacity->setValue(100 * (1.0 - d->data->opacity()));
  148     d->lineEditShader->setText(d->data->shader());
  149     this->initComboBoxShaderValue();
  152     connect(d->colorButton, SIGNAL(colorChanged(QColor)),
this, SLOT(
onColorChanged(QColor)));
  154     connect(d->colorButton, SIGNAL(colorChanged(QColor)),
this, SLOT(
  156     connect(d->sliderOpacity, SIGNAL(valueChanged(
int)),
this, SLOT(
onOpacityChanged(
int)));
  158     connect(d->lineEditShader, SIGNAL(textChanged(QString)),
this, SLOT(
onShaderChanged(QString)));
  159     connect(d->comboBoxShader, SIGNAL(currentIndexChanged(QString)),
this, SLOT(
onLineEditShaderChanged(QString)));
  166     d->data->setColor(color);
  176     if(d->lineEditShader->isEnabled())
  179         fileToOpen = QFileDialog::getOpenFileName(
this, tr(
"Open shader"),
"", tr(
"vs file (*.vs)"));
  180         d->lineEditShader->setText(fileToOpen);
  184 void axlInspectorObjectComposite::initComboBoxShaderValue(
void)
  186     if(d->comboBoxShader) {
  192         QDir dirShader(
":axlShader/shader/");
  193         dirShader.setFilter(QDir::Files | QDir::Hidden | QDir::NoSymLinks);
  195         dirShader.setNameFilters(filters);
  197         QFileInfoList list = dirShader.entryInfoList();
  202         QSettings settings(
"inria",
"dtk");
  204         settings.beginGroup(
"shader");
  205         QString defaultPathShader = settings.value(
"path", defaultPath).toString();
  206         defaultPathShader.append(
  208         QDir defaultDirShader(defaultPathShader);
  209         defaultDirShader.setNameFilters(filters);
  210         QFileInfoList list2 = defaultDirShader.entryInfoList();
  216         for (
int i = 0; i < list.size(); ++i) {
  217             if(!items.contains(list.at(i).fileName()))
  218                 items << list.at(i).fileName();
  222         int indInitShader = -1;
  223         int indCurrentShader = -1;
  225         foreach(QString item, items) {
  227             d->comboBoxShader->addItem(item);
  229             QFileInfo currentFileInfo(d->lineEditShader->text());
  231             if(currentFileInfo.exists())
  233                 if(item == currentFileInfo.fileName())
  234                     indInitShader =indCurrentShader;
  239         if(indInitShader != -1)
  240             d->comboBoxShader->setCurrentIndex(indInitShader);
  247     d->data->setShader(shader);
  258     QDir dirShader(
  259     dirShader.setFilter(QDir::Files | QDir::Hidden | QDir::NoSymLinks);
  261     QFileInfo currentFile(dirShader, shader);
  262     if(!currentFile.exists())
  264         QSettings settings(
"inria",
"dtk");
  266         settings.beginGroup(
"shader");
  267         QString defaultPathShader = settings.value(
  268         defaultPathShader.append(
  270         QDir defaultDirShader(defaultPathShader);
  271         currentFile = QFileInfo(defaultDirShader, shader);
  275     d->lineEditShader->setText(currentFile.absoluteFilePath());
  282         d->comboBoxShader->setEnabled(
true);
  283         d->lineEditShader->setEnabled(
true);
  284         d->buttonShader->setEnabled(
true);
  291         d->comboBoxShader->setEnabled(
false);
  292         d->lineEditShader->setEnabled(
false);
  293         d->buttonShader->setEnabled(
false);
  303     double opacity_d = 1.0 - 0.01 * opacity;
  304     d->data->setOpacity(opacity_d);
void onOpacityChanged(int opacity)
void modifiedProperty(dtkAbstractData *, int)
void moveCurrentPoint(double u, double v, dtkAbstractData *data)
bool caseInsensitiveLessThan(const QString &s1, const QString &s2)
void onShowCurrentPoint(double u, double v)
void hideCurrentPoint(double u, double v, dtkAbstractData *data)
axlInspectorObjectComposite(QWidget *parent=0)
void onColorChanged(QColor color)
void onLineEditShaderChanged(QString)
void onMoveCurrentPoint(double u, double v)
void setData(axlAbstractDataComposite *data)
void onHideCurrentPoint(double u, double v)
void onShaderStateChanged(bool isShader)
~axlInspectorObjectComposite(void)
void onShaderChanged(QString)
void showCurrentPoint(double u, double v, dtkAbstractData *data)
QSize sizeHint(void) const
