| addField(axlAbstractField *field) | axlAbstractData | |
| area(double tol) | axlAbstractSurfaceParametric | virtual |
| axlAbstractData(axlAbstractData *parent=NULL) | axlAbstractData | |
| axlAbstractData(const axlAbstractData &data) | axlAbstractData | |
| axlAbstractSurface(void) | axlAbstractSurface | |
| axlAbstractSurfaceParametric(void) | axlAbstractSurfaceParametric | |
| axlConeParametric(axlAbstractSurfaceParametric *parent=0) | axlConeParametric | |
| axlConeParametric(axlCone *cone, axlPoint *r) | axlConeParametric | |
| axlConeParametric(const axlCone &cone, const axlPoint &r) | axlConeParametric | |
| axlConeParametric(const axlConeParametric &other) | axlConeParametric | |
| changeFieldName(QString fieldName) | axlAbstractData | |
| color | axlAbstractData | |
| color(void) const | axlAbstractData | |
| convertDataToQVariant(void) const | axlAbstractData | virtual |
| convertQVariantToData(const QVariantList &data) | axlAbstractData | virtual |
| countCells(void) | axlAbstractSurfaceParametric | virtual |
| description(void) const | axlConeParametric | virtual |
| dimension(void) const | axlAbstractSurface | virtual |
| editable(void) | axlAbstractData | |
| endParam_u(void) | axlAbstractSurfaceParametric | virtual |
| endParam_u(int numCell) | axlAbstractSurfaceParametric | virtual |
| endParam_v(void) | axlAbstractSurfaceParametric | virtual |
| endParam_v(int numCell) | axlAbstractSurfaceParametric | virtual |
| eval(double u, double v) | axlConeParametric | virtual |
| eval(axlPoint *point, double u, double v) | axlConeParametric | virtual |
| eval(double &x, double &y, double &z, double u, double v) | axlConeParametric | virtual |
| axlAbstractSurfaceParametric::eval(double u, double v, int derivs, bool u_from_right=true, bool v_from_right=true, double resolution=1.0e-12) | axlAbstractSurfaceParametric | virtual |
| axlAbstractSurfaceParametric::eval(axlPoint *point, double u, double v, int numCell) | axlAbstractSurfaceParametric | virtual |
| eval2(double u, double v) | axlAbstractSurfaceParametric | virtual |
| fields(void) | axlAbstractData | |
| getCone(void) const | axlConeParametric | |
| getR(void) const | axlConeParametric | |
| hasCells(void) | axlAbstractSurfaceParametric | virtual |
| identifier(void) const | axlConeParametric | virtual |
| mesh(void) | axlAbstractData | |
| modifiedField(void) | axlAbstractData | signal |
| modifiedGeometry(void) | axlAbstractData | signal |
| modifiedProperty(void) | axlAbstractData | signal |
| modifiedStructure(void) | axlAbstractData | signal |
| modifyR(double *r) | axlConeParametric | |
| normal(axlPoint *normal, double u, double v) | axlAbstractSurfaceParametric | virtual |
| normal(double u, double v) | axlAbstractSurfaceParametric | virtual |
| normal(dtkDeprecated::dtkVector3D< double > *normal, double u, double v) | axlAbstractSurfaceParametric | virtual |
| normal(axlPoint *normal, double u, double v, int numCell) | axlAbstractSurfaceParametric | virtual |
| numSamples_u(void) | axlAbstractSurfaceParametric | virtual |
| numSamples_u(int numCell) | axlAbstractSurfaceParametric | virtual |
| numSamples_v(void) | axlAbstractSurfaceParametric | virtual |
| numSamples_v(int numCell) | axlAbstractSurfaceParametric | virtual |
| onConeChanged(axlCone *cone) | axlConeParametric | slot |
| onRChanged(axlPoint *r) | axlConeParametric | slot |
| opacity | axlAbstractData | |
| opacity(void) const | axlAbstractData | |
| operator=(const axlConeParametric &other) | axlConeParametric | |
| parameterOf(const axlPoint &point, double &um, double &vm) | axlConeParametric | virtual |
| samples_u | axlAbstractSurfaceParametric | |
| samples_u(void) const | axlAbstractSurfaceParametric | |
| samples_v | axlAbstractSurfaceParametric | |
| samples_v(void) const | axlAbstractSurfaceParametric | |
| setColor(double r, double g, double b) | axlAbstractData | |
| setColor(const QColor &color) | axlAbstractData | slot |
| setCone(axlCone *cone) | axlConeParametric | |
| setCone(const axlCone &cone) | axlConeParametric | |
| setEditable(bool edit) | axlAbstractData | slot |
| setMesh(axlMesh *mesh) | axlAbstractData | |
| setNumSamples_u(int numSamples) | axlAbstractSurfaceParametric | virtual |
| setNumSamples_v(int numSamples) | axlAbstractSurfaceParametric | virtual |
| setOpacity(const double &opacity) | axlAbstractData | slot |
| setR(axlPoint *r) | axlConeParametric | |
| setSamples_u(const int &color) | axlAbstractSurfaceParametric | slot |
| setSamples_v(const int &color) | axlAbstractSurfaceParametric | slot |
| setShader(const QString &shader) | axlAbstractData | slot |
| setSize(const double &size) | axlAbstractData | slot |
| setStripes(int stripes) | axlAbstractSurfaceParametric | virtual |
| setUpdateView(bool updateView) | axlAbstractData | |
| shader | axlAbstractData | |
| shader(void) const | axlAbstractData | |
| size | axlAbstractData | |
| size(void) const | axlAbstractData | |
| startParam_u(void) | axlAbstractSurfaceParametric | virtual |
| startParam_u(int numCell) | axlAbstractSurfaceParametric | virtual |
| startParam_v(void) | axlAbstractSurfaceParametric | virtual |
| startParam_v(int numCell) | axlAbstractSurfaceParametric | virtual |
| stripes(void) | axlAbstractSurfaceParametric | virtual |
| surface(void) | axlAbstractSurface | virtual |
| toAxlMesh(void) | axlAbstractSurface | virtual |
| touchField(void) | axlAbstractData | virtualslot |
| touchGeometry(void) | axlAbstractData | slot |
| touchProperty(void) | axlAbstractData | slot |
| touchStructure(void) | axlAbstractData | slot |
| updateFieldList(QString nameField) | axlAbstractData | |
| updateView(void) | axlAbstractData | |
| ~axlAbstractData(void) | axlAbstractData | virtual |
| ~axlAbstractSurface(void) | axlAbstractSurface | virtual |
| ~axlAbstractSurfaceParametric(void) | axlAbstractSurfaceParametric | virtual |
| ~axlConeParametric(void) | axlConeParametric | virtual |
