#include <axlAbstractNumberType.h>
 Public Types | |
| enum | Type { Int, Float, Double } |
Public Slots | |
| void | setValue (double newValue) |
  Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
Public Member Functions | |
| axlAbstractNumberType (QObject *parent=0) | |
| ~axlAbstractNumberType (void) | |
| virtual QString | description (void) const |
| virtual QString | identifier (void) const |
| double | value (void) const |
| axlAbstractNumberType & | operator= (const axlAbstractNumberType &other) |
| QString | objectType (void) const |
  Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object.  More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object.  More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed.  More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object.  More... | |
| virtual QVariantList | convertDataToQVariant (void) const |
| Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData.  More... | |
| virtual int | convertQVariantToData (const QVariantList &data) |
| Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0.  More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
Friends | |
| QDebug | operator<< (QDebug dbg, axlAbstractNumberType line) |
| QDebug | operator<< (QDebug dbg, axlAbstractNumberType &line) |
| QDebug | operator<< (QDebug dbg, axlAbstractNumberType *line) |
Additional Inherited Members | |
  Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
  Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
Definition at line 28 of file axlAbstractNumberType.h.
| Enumerator | |
| Int | |
| Float | |
| Double | |
Definition at line 32 of file axlAbstractNumberType.h.
| axlAbstractNumberType::axlAbstractNumberType | ( | QObject * | parent = 0 | ) |
| axlAbstractNumberType::~axlAbstractNumberType | ( | void | ) |
  virtual |
  virtual |
| QString axlAbstractNumberType::objectType | ( | void | ) | const |
| axlAbstractNumberType& axlAbstractNumberType::operator= | ( | const axlAbstractNumberType & | other | ) |
  slot |
| double axlAbstractNumberType::value | ( | void | ) | const |
  friend |
  friend |
  friend |
