#include <axlAbstractCurveAlgebraic.h>
Public Types | |
typedef QMap< double, axlPoint > | Sample |
Signals | |
void | updated (void) |
void | samplingChanged () |
void | modifiedGeometry (void) |
void | modifiedStructure (void) |
void | modifiedField (void) |
void | modifiedProperty (void) |
Public Member Functions | |
axlAbstractCurveAlgebraic (void) | |
virtual | ~axlAbstractCurveAlgebraic (void) |
virtual void | setData (void *data) |
virtual void | setData (const QList< double > &box, const QString &) |
virtual QString | description (void) const |
axlAbstractCurve (void) | |
virtual | ~axlAbstractCurve (void) |
virtual int | dimension (void) const |
virtual bool | isPlanar (void) const |
virtual void * | curve (void) |
axlAbstractData (axlAbstractData *parent=NULL) | |
axlAbstractData (const axlAbstractData &data) | |
virtual | ~axlAbstractData (void) |
const QColor & | color (void) const |
const double & | opacity (void) const |
const double & | size (void) const |
const QString & | shader (void) const |
const bool & | editable (void) |
const bool & | updateView (void) |
void | setColor (double r, double g, double b) |
void | addField (axlAbstractField *field) |
Add a field to the field list of the object. More... | |
bool | updateFieldList (QString nameField) |
Check if a field with the same name is already applied on the object. More... | |
QString | changeFieldName (QString fieldName) |
axlMesh * | mesh (void) |
Return the mesh of that object is computed. More... | |
void | setMesh (axlMesh *mesh) |
Set a corresponding mesh for that object. More... | |
virtual QVariantList | convertDataToQVariant (void) const |
Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
virtual int | convertQVariantToData (const QVariantList &data) |
Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
void | setUpdateView (bool updateView) |
QList< axlAbstractField * > | fields (void) |
Additional Inherited Members | |
void | touchGeometry (void) |
void | touchProperty (void) |
void | touchStructure (void) |
virtual void | touchField (void) |
void | setColor (const QColor &color) |
void | setOpacity (const double &opacity) |
void | setSize (const double &size) |
void | setShader (const QString &shader) |
void | setEditable (bool edit) |
QColor | color |
double | opacity |
double | size |
QString | shader |
Definition at line 28 of file axlAbstractCurveAlgebraic.h.
typedef QMap<double, axlPoint> axlAbstractCurveAlgebraic::Sample |
Definition at line 34 of file axlAbstractCurveAlgebraic.h.
axlAbstractCurveAlgebraic::axlAbstractCurveAlgebraic | ( | void | ) |
Definition at line 30 of file axlAbstractCurveAlgebraic.cpp.
virtual |
Definition at line 35 of file axlAbstractCurveAlgebraic.cpp.
virtual |
Definition at line 53 of file axlAbstractCurveAlgebraic.cpp.
signal |
virtual |
virtual |
Definition at line 41 of file axlAbstractCurveAlgebraic.cpp.
signal |
