19 #include <dtkCoreSupport/dtkAbstractData.h>
   20 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
   40     return "axlVolumeDiscreteReader";
   45     return "axlVolumeDiscreteReader";
   50     return QStringList() <<
"axlVolumeDiscrete";
   60     QDomElement element = node.toElement();
   62     if(element.tagName() !=
"volume")
   65     if(element.attribute(
"type") !=
"discrete")
   79     return !this->
accept(node);
   84     QDomElement element = node.toElement();
   88     QString name = element.attribute(
"name");
   91         currentVolume->setObjectName(name);
   95     QDomNodeList dimension = element.elementsByTagName(
"dimension");
   96     if(!dimension.isEmpty()){
   97         QDomElement dimensionElement = dimension.at(0).toElement();
   99         QStringList dimensions = dimensionElement.text().simplified().split(QRegExp(
"\\s+"));
  101         if(dimensions.size() == 3)
  103             currentVolume->
setDimensions(dimensions[0].toInt(),dimensions[1].toInt(),dimensions[2].toInt());
  109     QDomNodeList values = element.elementsByTagName(
"values");
  111     if(!values.isEmpty()){
  112         QDomElement scalarElement = values.at(0).toElement();
  113         scalar = scalarElement.text().simplified().split(QRegExp(
"\\s+"));
  120     for(
int i = 0;i < nx;i++){
  121         for(
int j = 0;j < ny;j++){
  122             for(
int k = 0;k < nz;k++){
  123                 number = scalar[nx*ny*k+ nx*j + i].toDouble();
  124                 currentVolume->
setValue(number,i,j,k);
  129     return currentVolume;
  139     if(!axl_reader->
accept(node))
  142     axl_reader->dtkAbstractDataReader::read(this->file());
axlVolumeDiscreteReader(void)
QStringList handled(void) const
axlAbstractData * read(const QDomNode &node)
bool reject(const QDomNode &node)
int yDimension(void) const
void setValue(double value, int i, int j, int k)
static bool registered(void)
virtual axlAbstractData * read(const QDomNode &node)=0
int xDimension(void) const
QString description(void) const
dtkAbstractDataReader * createaxlVolumeDiscreteReader(void)
QString identifier(void) const
int zDimension(void) const
void setDimensions(unsigned int x, unsigned int y, unsigned int z)
bool hasChildNode(QDomElement element, const QString &tag)
virtual bool accept(const QDomNode &node)=0
axlAbstractData * dataByReader(axlAbstractDataReader *axl_reader, const QDomNode &node)
Class axlAbstractData defines an API for all type of axel data.
~axlVolumeDiscreteReader(void)
static dtkAbstractDataFactory * dataFactSingleton
