20 #include <dtkCoreSupport/dtkAbstractData.h>
   21 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
   40     return "axlShapeBSplineWriter";
   45     return "axlShapeBSplineWriter";
   50     return QStringList() <<
"axlShapeBSpline";
   55     return dtkAbstractDataFactory::instance()->registerDataWriterType(
"axlShapeBSplineWriter", QStringList(),
createaxlShapeBSplineWriter);
   73     return !this->
accept(data);
   81     QDomElement surfElement = doc->createElement(
"surface");
   82     surfElement.setAttribute(
"name", surf->name());
   85     surfElement.setAttribute(
"type",
"patch");
   88     surfElement.setAttribute(
"size", QString::number(surf->
size()));
   91     QColor qcolor = surf->
color();
   93     QTextStream(&color) << QString::number(qcolor.red()) <<
   94                         << QString::number(qcolor.green()) <<
   95                         << QString::number(qcolor.blue()) <<
   96                         << QString::number(surf->
opacity());
   97     surfElement.setAttribute(
"color", color);
  100     QString shader = surf->
shader();
  101     QFileInfo shaderFileInfo(shader);
  102     surfElement.setAttribute(
"shader", shaderFileInfo.fileName());
  107     surfElement.setAttribute(
"nb_faces", surf->
countFaces());
  108     surfElement.setAttribute(
"orderu", surf->
order_u());
  109     surfElement.setAttribute(
"orderv", surf->
order_v());
  112     QDomElement verticesElement = doc->createElement(
"points");
  114         QString coordsString = QString::number(surf->
getCoef(k).
x()) +
  115                 + QString::number(surf->
getCoef(k).
y()) +
  116                 + QString::number(surf->
getCoef(k).
z()) +
"\n\t";
  117         QDomText coordsDomText = doc->createTextNode(coordsString);
  118         verticesElement.appendChild(coordsDomText);
  120     surfElement.appendChild(verticesElement);
  123     QDomElement edgesElement = doc->createElement(
"edges");
  125         QDomElement edgeElement = doc->createElement(
"edge");
  126         edgeElement.setAttribute(
"id", k);
  130         QDomElement controlP = doc->createElement(
"controlPoints");
  133             QDomText coordsDomText = doc->createTextNode(coordsString);
  134             controlP.appendChild(coordsDomText);
  137         edgeElement.appendChild(controlP);
  138         edgeElement.setAttribute(
"tag", currEdge->
tag);
  139         edgesElement.appendChild(edgeElement);
  142     surfElement.appendChild(edgesElement);
  145     QDomElement facesElement = doc->createElement(
"faces");
  146     for (
int k = 0; k < surf->
countFaces(); k++) {
  147         QDomElement faceElement = doc->createElement(
"face");
  148         faceElement.setAttribute(
"id", k);
  152         QDomElement controlP = doc->createElement(
"controlPoints");
  155             QDomText coordsDomText = doc->createTextNode(coordsString);
  156             controlP.appendChild(coordsDomText);
  159         QDomElement edgeInd = doc->createElement(
"nbpts");
  161             QString coordsString = QString::number(currFace->
nbpts_u) +
" " + QString::number(currFace->
nbpts_v);
  162             QDomText coordsDomText = doc->createTextNode(coordsString);
  163             edgeInd.appendChild(coordsDomText);
  166         faceElement.appendChild(controlP);
  167         faceElement.appendChild(edgeInd);
  168         facesElement.appendChild(faceElement);
  170     surfElement.appendChild(facesElement);
  176 QDomElement axlShapeBSplineWriter::elementByWriter(
axlAbstractDataWriter *axl_writer, QDomDocument *doc, dtkAbstractData *data)
  183     if(!axl_writer->
accept(data))
  186     element = axl_writer->
write(doc, data);
axlPoint getCoef(int index) const
Get a coefficient of the surface.
int order_u() const
Return the order of the surface for the u parameter.
Edge * getEdge(int i)
Return edge.
bool accept(dtkAbstractData *data)
int countFaces(void)
Return how many faces.
int order_v() const
Return the order of the surface for the v parameter.
QVector< int > controlPointsIndices
static bool registered(void)
bool reject(dtkAbstractData *data)
virtual bool accept(dtkAbstractData *data)=0
Face * getFace(int i)
Return face.
QStringList handled(void) const
QString description(void) const
QString identifier(void) const
dtkAbstractDataWriter * createaxlShapeBSplineWriter(void)
int countBoundaryEdges() const
Return how many edges.
QDomElement write(QDomDocument *doc, dtkAbstractData *data)
int countControlPoints() const
Modified a coefficient of the surface.
Class axlShapeBSpline defines a set of boundary curves (Edges) and bspline surface patches (Face)...
virtual QDomElement write(QDomDocument *doc, dtkAbstractData *data)=0
Return the "axlShapeBSpline" identifier.Useful for data factory.
