23 #include <dtkGuiSupport/dtkColorButton.h>
   26 #include <dtkCoreSupport/dtkAbstractProcessFactory.h>
   33 class axlInspectorToolCreatorDataDynamicDialogPrivate
   36     QSlider *sliderOpacity;
   37     dtkColorButton *colorButton;
   40     QLineEdit *process_name;
   41     QLineEdit *listDoubleValues;
   44     QLabel *messageToDisplay;
   65     d->layout =
new QVBoxLayout(
this);
   68     d->sliderOpacity =
new QSlider(Qt::Horizontal,
this);
   70     QHBoxLayout *layoutOpacity =
new QHBoxLayout;
   71     layoutOpacity->addWidget(
new QLabel(
"Opacity",
this));
   72     layoutOpacity->addWidget(d->sliderOpacity);
   73     d->sliderOpacity->setMaximum(100);
   76     d->colorButton =
new dtkColorButton(
this);
   78     QHBoxLayout *layoutColorButton =
new QHBoxLayout;
   79     layoutColorButton->addWidget(
new QLabel(
"Color",
this));
   80     layoutColorButton->addWidget(d->colorButton);
   81     d->colorButton->setColor(QColor(
"#a0a0a4"));
   84     QHBoxLayout *layoutProcessName =
new QHBoxLayout;
   85     layoutProcessName->addWidget(
new QLabel(
"Process name",
this));
   86     d->process_name =
new QLineEdit(
this);
   87     QCompleter *completer =
new QCompleter(dtkAbstractProcessFactory::instance()->creators(),
this);
   88     completer->setCaseSensitivity(Qt::CaseSensitive);
   89     d->process_name->setCompleter(completer);
   91     layoutProcessName->addWidget(d->process_name);
   92     connect(d->process_name, SIGNAL(textChanged(QString)),
this, SLOT(
setProcessName()));
   95     QHBoxLayout *layoutDoubleValues =
new QHBoxLayout;
   96     QLabel *labelParameters =
new QLabel(
"double inputs values",
this);
   97     layoutDoubleValues->addWidget(labelParameters);
   98     d->listDoubleValues =
new QLineEdit(
this);
   99     layoutDoubleValues->addWidget(d->listDoubleValues);
  102     d->messageToDisplay =
new QLabel(
this);
  103     d->messageToDisplay->setStyleSheet(
"color: #ff0000;");
  104     d->messageToDisplay->setVisible(
false);
  107     d->errorMessage =
new QLabel(
"wrong inputs number or type,\n please select them as describe above");
  108     d->errorMessage->setStyleSheet(
"color: #ff0000;");
  109     d->errorMessage->setVisible(
false);
  112     QHBoxLayout *layoutIsDynamic =
new QHBoxLayout(
this);
  113     QLabel *labelIsStatic =
new QLabel(
"static",
this);
  114     layoutIsDynamic->addWidget(labelIsStatic);
  115     d->isStatic =
new QCheckBox(
this);
  116     layoutIsDynamic->addWidget(d->isStatic);
  119     QPushButton *button =
new QPushButton(
"Create",
this);
  120     connect(button, SIGNAL(clicked()),
this, SLOT(
run()));
  122     d->layout->addWidget(
new QLabel(
"axlInspectorToolCreatorDataDynamic",
this));
  123     d->layout->addLayout(layoutOpacity);
  124     d->layout->addLayout(layoutColorButton);
  125     d->layout->addLayout(layoutProcessName);
  126     d->layout->addWidget(d->messageToDisplay);
  127     d->layout->addLayout(layoutDoubleValues);
  128     d->layout->addWidget(d->dialog);
  129     d->layout->addLayout(layoutIsDynamic);
  130     d->layout->addWidget(button);
  131     d->layout->addWidget(d->errorMessage);
  133     d->listDoubleValues->hide();
  134     labelParameters->hide();
  155     d->controller = controller;
  156     d->dialog->setController(controller);
  170     QString processName = d->process_name->text();
  172     if(!processName.isEmpty()){
  179                 d->layout->removeWidget(d->dialog);
  184                 d->dialog = newDialog;
  185                 d->dialog->setController(d->controller);
  186                 d->messageToDisplay->hide();
  187                 d->listDoubleValues->hide();
  189                 if(dynamic_cast<axlInspectorToolCreator *>(d->dialog))
  192                     d->dialog->setController(d->controller);
  194                 QObjectList listChildren = d->dialog->children();
  195                 for(
int i = 0; i < listChildren.size();i++){
  196                     if(dynamic_cast<QPushButton *>(listChildren.at(i))  ){
  197                         dynamic_cast<QWidget *
>(listChildren.at(i))->hide();
  198                     }
else if(dynamic_cast<QSlider *>(listChildren.at(i))){
  199                         dynamic_cast<QWidget *
  200                     }
else if(dynamic_cast<QLabel *>(listChildren.at(i))){
  201                         if(dynamic_cast<QLabel *>(listChildren.at(i))->text() ==
"Opacity" ||
"Color")
  202                             dynamic_cast<QWidget *>(listChildren.at(i))->hide();
  210                 d->layout->insertWidget(6, d->dialog);
  214                 QString textToDisplay ;
  218                     textToDisplay.append(
"\n double inputs values: ");
  219                 d->messageToDisplay->setText(textToDisplay);
  220                 d->messageToDisplay->show();
  222                     d->listDoubleValues->show();
  226             d->listDoubleValues->hide();
  227             d->messageToDisplay->setText(
"This process doesn't exist");
  228             d->messageToDisplay->show();
  240     d->errorMessage->hide();
  243     QString processName = d->process_name->text();
  244     if(!processName.isEmpty()){
  249     if(d->isStatic->isChecked()){
  258             if(item->text(2) ==
"Selected"|| item->text(2) ==
"Editable")
  260                 if(dynamic_cast<axlAbstractData *>(d->controller->data(item))) {
  261                     if(
axlDataDynamic *axldata = dynamic_cast<axlDataDynamic *>(d->controller->data(item)))
  262                         dynamicData->
setInput(axldata->outputs());
  264                         dynamicData->
setInput(d->controller->data(item));
  271         QString doubleValues = d->listDoubleValues->text();
  272         if(d->listDoubleValues->isVisible() && !doubleValues.isEmpty()){
  273             int sizeList = doubleValues.size();
  276             while(indice <= sizeList){
  277                 if(doubleValues.at(indice).isSpace() || indice ==(sizeList)){
  278                     if(!value.isEmpty()){
  279                         bool hasLetter =
false;
  280                         for(
int j = 0;j <value.size();j++){
  281                             if(value.at(j).isLetter())
  285                             double newInputValue = value.toDouble();
  293                     value.append(doubleValues.at(indice));
  298         QObjectList list = this->children();
  299         for(
int i = 0;i < list.size();i++){
  300             if(QFrame *frame = dynamic_cast<QFrame *>(list.at(i))){
  301                 QObjectList list1 = frame->children();
  302                 for(
int j = 0;j < list1.size();j++){
  303                     if(QDoubleSpinBox *box = dynamic_cast<QDoubleSpinBox *>(list1.at(j))){
  304                         double value = box->value();
  307                     }
else if(QSpinBox *box = dynamic_cast<QSpinBox *>(list1.at(j))){
  308                         int value = box->value();
  321             if(d->dialog && dynamic_cast<axlInspectorToolCreator *>(d->dialog)){
  323                 for(
int j = 0;j< listInputs.size();j++){
  324                     dynamicData->
setInput(listInputs.at(j));
  329                     for(
int k = 0; k < dynamicData->
inputs().size();k++){
  330                         if(!(dynamicData->
inputs().at(k)->identifier() ==
"axlDouble") && !(dynamicData->
"axlInteger")){
  331                             dynamicData->
inputs().at(k)->setColor(d->colorButton->color());
  332                             double opacity = 1.0 - 0.01 * d->sliderOpacity->value();
  333                             dynamicData->
inputs().at(k)->setOpacity(opacity);
  339                     dynamicData->
  340                     double opacity = 1.0 - 0.01 * d->sliderOpacity->value();
  346                     d->errorMessage->show();
  347                     if(d->dialog && dynamic_cast<axlInspectorToolCreator *>(d->dialog)){
  359             dynamicData->
  360             double opacity = 1.0 - 0.01 * d->sliderOpacity->value();
virtual void update(void)
Update the dynamic object.
int setProcess(QString processName)
Create the dynamic object process only with the name of its latter.
virtual bool hasParameters(void)
void setType(axlDataDynamic::Type type)
Sets the type of the object. Type could be dynamic or static.
Class axlDouble defines a double.
axlAbstractData * outputs(void)
Return the first output of the list.
axlAbstractProcess * process(void)
Return the process.
Class axlDataDynamic defines a dynamic object.
void setInput(dtkAbstractData *data, int channel=0)
Add input;.
virtual QString description(void) const
Class axlInteger defines an integer.
QList< axlAbstractData * > inputs(void)
Return input list;.
void setOpacity(const double &opacity)
void clearInputs(void)
Clear input list.
void setColor(double r, double g, double b)
virtual QString identifier(void) const
