18 #include "axlCoreExport.h"
26 class axlIntegerPrivate;
38 virtual QString description(
void)
const;
39 virtual QString identifier(
void)
const;
41 int value(
void)
const;
53 void setValue(
int newValue);
79 #endif // AXLINTEGER_H
Class axlPoint defines 3D points.
QDebug operator<<(QDebug dbg, axlInteger point)
virtual int convertQVariantToData(const QVariantList &data)
Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was suc...
virtual QVariantList convertDataToQVariant(void) const
Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData...
dtkAbstractData * createaxlInteger(void)
Class axlInteger defines an integer.
Class axlAbstractData defines an API for all type of axel data.
