14 #include "axlCoreExport.h"
15 #ifndef AXLFIELDPARAMETRICCURVE_H
16 #define AXLFIELDPARAMETRICCURVE_H
20 class axlFieldParametricCurvePrivate;
51 virtual double scalar(
double u,
double v = 0.,
double w = 0.);
52 virtual double *
vector(
double u,
double v = 0.,
double w = 0.);
53 virtual double *
tensor(
double u,
double v = 0.,
double w = 0.);
66 axlFieldParametricCurvePrivate *d;
72 #endif // AXLFIELDPARAMETRICCURVE_H
virtual double scalar(double u, double v=0, double w=0)
Returns the value of the parametric field at the parameters values in input.
virtual void update(void)
virtual void setFunction(axlAbstractData *data)
Returns the description of the field.
virtual double * tensor(double u, double v=0, double w=0)
Returns the value of the spatial field at the coordinates point entered.
virtual void setCurve(axlAbstractData *Curve)
Sets the support Curve of the field.
virtual axlAbstractData * getFunction(void)
Class axlFieldParametricCurve defines an API for field which owns a BSpline curve.
AXLCORE_EXPORT dtkAbstractData * createaxlFieldParametricCurve(void)
Class axlAbstractFieldParametricCurve defines an API for parametric field.
virtual int size(void)
Returns number of parameters on which the field is evaluated.
virtual QString identifier(void) const
virtual double end_u(void)
Returns the last v-value parameter.
virtual double start_u(void)
Returns the first u-value parameter.
Class axlAbstractData defines an API for all type of axel data.
virtual double numbersample_u(void)
Returns the number of u-parameters.
virtual QString description(void) const
virtual double * vector(double u, double v=0, double w=0)
Returns the value of the parametric field evaluated at the parameters in input.
