19 #include <dtkCoreSupport/dtkAbstractProcessFactory.h>
   25 class axlCylinderCreatorPrivate{
   63     if(process->output()){
   64         d->output =
dynamic_cast<axlCylinder *
>(process->output());
   79     if(dynamic_cast<axlPoint *>(newData)){
   83         }
else if(channel == 1){
   97     if(d->output == NULL){
   98         if(d->point1 && d->point2 && (d->radius >= 0.0)){
  100             d->output = newCylinder;
  106         if(d->point1 && d->point2 && (d->radius >= 0.0)){
  107             d->output->setValues(d->point1, d->point2, d->radius);
  118     return "create a cylinder with two points for its axe \n and its radius value";
  123     return "axlCylinderCreator";
virtual ~axlCylinderCreator(void)
Class axlPoint defines 3D points.
void copyProcess(axlAbstractProcess *process)
static bool registered(void)
Class axlCylinder defines 3D cylinders.
virtual dtkAbstractData * output(void)
axlCylinderCreator(QObject *parent=0)
virtual QString identifier(void) const
virtual QString description(void) const
virtual void setParameter(double data)
Class axlAbstractData defines an API for all type of axel data.
virtual void setInput(dtkAbstractData *newData, int channel)
dtkAbstractProcess * createaxlCylinderCreator(void)
virtual axlAbstractData * getInput(int channel) const
