#include <axlVolumeDiscreteProcessCreator.h>
Public Member Functions | |
| axlVolumeDiscreteProcessCreator (void) | |
| ~axlVolumeDiscreteProcessCreator (void) | |
| void | copyProcess (axlAbstractProcess *process) |
| bool | hasParameters (void) |
| virtual int | update (void) |
| virtual QString | description (void) const |
| virtual QString | identifier (void) const |
| QString | form (void) const |
| Description of the form for the dialog with the process. More... | |
| virtual void | setInput (dtkAbstractData *newData, int channel) |
| virtual void | setParameter (int value, int channel) |
| virtual dtkAbstractData * | output (void) |
Public Member Functions inherited from axlAbstractCreatorProcess | |
| axlAbstractCreatorProcess (QObject *parent=0) | |
| virtual | ~axlAbstractCreatorProcess (void) |
| axlAbstractData * | getInput (int channel) const |
| virtual dtkAbstractData * | output (int channel) |
| virtual int | channelCount (void) |
Public Member Functions inherited from axlAbstractProcess | |
| axlAbstractProcess (void) | |
| virtual | ~axlAbstractProcess (void) |
| virtual void | setDescription (QString description) |
| virtual void | setIdentifier (QString identifier) |
Static Public Member Functions | |
| static bool | registered (void) |
Definition at line 30 of file axlVolumeDiscreteProcessCreator.h.
| axlVolumeDiscreteProcessCreator::axlVolumeDiscreteProcessCreator | ( | void | ) |
Definition at line 41 of file axlVolumeDiscreteProcessCreator.cpp.
| axlVolumeDiscreteProcessCreator::~axlVolumeDiscreteProcessCreator | ( | void | ) |
Definition at line 47 of file axlVolumeDiscreteProcessCreator.cpp.
virtual |
Reimplemented from axlAbstractProcess.
Definition at line 61 of file axlVolumeDiscreteProcessCreator.cpp.
virtual |
Reimplemented from axlAbstractCreatorProcess.
Definition at line 142 of file axlVolumeDiscreteProcessCreator.cpp.
inlinevirtual |
The string use to describe the form is formatted as follows:
where:
Here is an example of such a declaration:
Definition at line 63 of file axlVolumeDiscreteProcessCreator.h.
virtual |
returns true if the process needs parameters. By default, equals false.
Definition at line 68 of file axlVolumeDiscreteProcessCreator.cpp.
virtual |
Definition at line 147 of file axlVolumeDiscreteProcessCreator.cpp.
virtual |
Definition at line 80 of file axlVolumeDiscreteProcessCreator.cpp.
static |
Definition at line 151 of file axlVolumeDiscreteProcessCreator.cpp.
virtual |
Definition at line 86 of file axlVolumeDiscreteProcessCreator.cpp.
virtual |
Definition at line 93 of file axlVolumeDiscreteProcessCreator.cpp.
virtual |
Definition at line 106 of file axlVolumeDiscreteProcessCreator.cpp.
