axlToMesh is a process that allow you to convert data to mesh. More...
#include <axlToMesh.h>
 Signals | |
| void | dataInserted (axlAbstractData *data) |
Public Member Functions | |
| axlToMesh (QObject *parent=0) | |
| ~axlToMesh (void) | |
| axlAbstractData * | getInput (int channel) const |
| virtual int | update (void) |
| QString | description (void) const |
| QString | identifier (void) const |
| dtkAbstractData * | output (int channel) |
| dtkAbstractData * | output (void) |
| void | setInput (dtkAbstractData *newData, int channel=0) |
| int | channelCount (void) |
| QString | form (void) const |
| Description of the form for the dialog with the process.  More... | |
  Public Member Functions inherited from axlAbstractProcess | |
| axlAbstractProcess (void) | |
| virtual | ~axlAbstractProcess (void) |
| virtual void | copyProcess (axlAbstractProcess *process) |
| virtual bool | hasParameters (void) |
| virtual void | setDescription (QString description) |
| virtual void | setIdentifier (QString identifier) |
Convert all Input selected Data to axlMesh. Only data with converter will be converted.
Definition at line 27 of file axlToMesh.h.
| axlToMesh::axlToMesh | ( | QObject * | parent = 0 | ) |
Definition at line 36 of file axlToMesh.cpp.
| axlToMesh::~axlToMesh | ( | void | ) |
Definition at line 40 of file axlToMesh.cpp.
| int axlToMesh::channelCount | ( | void | ) |
Definition at line 99 of file axlToMesh.cpp.
  signal |
  virtual |
Reimplemented from axlAbstractProcess.
Definition at line 139 of file axlToMesh.cpp.
  inlinevirtual |
The string use to describe the form is formatted as follows:
where:
Here is an example of such a declaration:
Definition at line 57 of file axlToMesh.h.
| axlAbstractData * axlToMesh::getInput | ( | int | channel | ) | const |
Definition at line 46 of file axlToMesh.cpp.
  virtual |
Definition at line 144 of file axlToMesh.cpp.
| dtkAbstractData * axlToMesh::output | ( | int | channel | ) |
Definition at line 55 of file axlToMesh.cpp.
| dtkAbstractData * axlToMesh::output | ( | void | ) |
Definition at line 64 of file axlToMesh.cpp.
| void axlToMesh::setInput | ( | dtkAbstractData * | newData, |
| int | channel = 0  |
Definition at line 70 of file axlToMesh.cpp.
  virtual |
Definition at line 105 of file axlToMesh.cpp.
