| addField(axlAbstractField *field) | axlAbstractData | |
| applyMatrix(double *matrix) | axlLine | |
| axlAbstractCurve(void) | axlAbstractCurve | |
| axlAbstractCurveParametric(void) | axlAbstractCurveParametric | |
| axlAbstractData(axlAbstractData *parent=NULL) | axlAbstractData | |
| axlAbstractData(const axlAbstractData &data) | axlAbstractData | |
| axlLine(QObject *parent=0) | axlLine | |
| axlLine(axlPoint *p1, axlPoint *p2, QObject *parent=0) | axlLine | |
| axlLine(const axlPoint &p1, const axlPoint &p2, QObject *parent=0) | axlLine | |
| axlLine(const axlLine &other) | axlLine | |
| changeFieldName(QString fieldName) | axlAbstractData | |
| color | axlAbstractData | |
| color(void) const | axlAbstractData | |
| convertDataToQVariant(void) const | axlLine | virtual |
| convertQVariantToData(const QVariantList &data) | axlLine | virtual |
| curve(void) | axlAbstractCurve | virtual |
| description(void) const | axlLine | virtual |
| dimension(void) const | axlAbstractCurve | virtual |
| editable(void) | axlAbstractData | |
| endParam(void) | axlAbstractCurveParametric | virtual |
| eval(double u) | axlAbstractCurveParametric | virtual |
| eval(axlPoint *point, double u) | axlAbstractCurveParametric | virtual |
| eval(double u, int derivs, bool from_right=true) | axlAbstractCurveParametric | virtual |
| fields(void) | axlAbstractData | |
| firstPoint(void) const | axlLine | |
| getBarycenterPoint(double coeff) | axlLine | |
| getMiddlePoint(void) | axlLine | |
| identifier(void) const | axlLine | virtual |
| isPlanar(void) const | axlAbstractCurve | virtual |
| length(double tolerance) | axlAbstractCurveParametric | virtual |
| mesh(void) | axlAbstractData | |
| modifiedField(void) | axlAbstractData | signal |
| modifiedGeometry(void) | axlAbstractData | signal |
| modifiedProperty(void) | axlAbstractData | signal |
| modifiedStructure(void) | axlAbstractData | signal |
| numSamples(void) | axlAbstractCurveParametric | virtual |
| onDirectChanged(bool direct) | axlAbstractCurveParametric | virtualslot |
| onFirstPointChanged(axlPoint *p1) | axlLine | |
| onSecondPointChanged(axlPoint *p2) | axlLine | |
| opacity | axlAbstractData | |
| opacity(void) const | axlAbstractData | |
| operator<<(QDebug dbg, axlLine line) | axlLine | friend |
| operator<<(QDebug dbg, axlLine &line) | axlLine | friend |
| operator<<(QDebug dbg, axlLine *line) | axlLine | friend |
| operator=(const axlLine &other) | axlLine | |
| parameterOf(const axlPoint &p) | axlAbstractCurveParametric | |
| planeDirection(void) | axlLine | |
| planeOrigineOrdinate(void) | axlLine | |
| point1 | axlLine | |
| point2 | axlLine | |
| samples | axlAbstractCurveParametric | |
| samples(void) const | axlAbstractCurveParametric | |
| secondPoint(void) const | axlLine | |
| setColor(double r, double g, double b) | axlAbstractData | |
| setColor(const QColor &color) | axlAbstractData | slot |
| setEditable(bool edit) | axlAbstractData | slot |
| setFirstPoint(axlPoint *p1) | axlLine | |
| setFirstPoint(double *p1) | axlLine | |
| setMesh(axlMesh *mesh) | axlAbstractData | |
| setNumSamples(int numSamples) | axlAbstractCurveParametric | virtual |
| setOpacity(const double &opacity) | axlAbstractData | slot |
| setSamples(const int &color) | axlAbstractCurveParametric | slot |
| setSecondPoint(axlPoint *p2) | axlLine | |
| setSecondPoint(double *p2) | axlLine | |
| setShader(const QString &shader) | axlAbstractData | slot |
| setSize(const double &size) | axlAbstractData | slot |
| setUpdateView(bool updateView) | axlAbstractData | |
| setValues(axlPoint *p1, axlPoint *p2) | axlLine | |
| shader | axlAbstractData | |
| shader(void) const | axlAbstractData | |
| size | axlAbstractData | |
| size(void) const | axlAbstractData | |
| startParam(void) | axlAbstractCurveParametric | virtual |
| touchField(void) | axlAbstractData | virtualslot |
| touchFirstPoint(const axlPoint &point) | axlLine | |
| touchGeometry(void) | axlAbstractData | slot |
| touchProperty(void) | axlAbstractData | slot |
| touchSecondPoint(const axlPoint &point) | axlLine | |
| touchStructure(void) | axlAbstractData | slot |
| updateFieldList(QString nameField) | axlAbstractData | |
| updateView(void) | axlAbstractData | |
| ~axlAbstractCurve(void) | axlAbstractCurve | virtual |
| ~axlAbstractCurveParametric(void) | axlAbstractCurveParametric | virtual |
| ~axlAbstractData(void) | axlAbstractData | virtual |
| ~axlLine(void) | axlLine | |
