#include <axlIntersection.h>
Signals | |
| void | dataInserted (axlAbstractData *data) |
Public Member Functions | |
| axlIntersection (QObject *parent=0) | |
| ~axlIntersection (void) | |
| axlAbstractData * | getInput (int channel) const |
| virtual int | update (void) |
| QString | description (void) const |
| QString | identifier (void) const |
| dtkAbstractData * | output (void) |
| void | setInput (dtkAbstractData *newData, int channel) |
| int | channelCount (void) |
| QString | form (void) const |
| Description of the form for the dialog with the process. More... | |
Public Member Functions inherited from axlAbstractProcess | |
| axlAbstractProcess (void) | |
| virtual | ~axlAbstractProcess (void) |
| virtual void | copyProcess (axlAbstractProcess *process) |
| virtual bool | hasParameters (void) |
| virtual void | setDescription (QString description) |
| virtual void | setIdentifier (QString identifier) |
Definition at line 30 of file axlIntersection.h.
| axlIntersection::axlIntersection | ( | QObject * | parent = 0 | ) |
Definition at line 36 of file axlIntersection.cpp.
| axlIntersection::~axlIntersection | ( | void | ) |
Definition at line 43 of file axlIntersection.cpp.
| int axlIntersection::channelCount | ( | void | ) |
Definition at line 80 of file axlIntersection.cpp.
signal |
virtual |
Reimplemented from axlAbstractProcess.
Definition at line 140 of file axlIntersection.cpp.
inlinevirtual |
The string use to describe the form is formatted as follows:
where:
Here is an example of such a declaration:
Definition at line 57 of file axlIntersection.h.
| axlAbstractData * axlIntersection::getInput | ( | int | channel | ) | const |
Definition at line 49 of file axlIntersection.cpp.
virtual |
Definition at line 145 of file axlIntersection.cpp.
| dtkAbstractData * axlIntersection::output | ( | void | ) |
Definition at line 64 of file axlIntersection.cpp.
| void axlIntersection::setInput | ( | dtkAbstractData * | newData, |
| int | channel | ||
Definition at line 70 of file axlIntersection.cpp.
virtual |
Definition at line 86 of file axlIntersection.cpp.
