#include <axlDataDynamicReader.h>
Public Member Functions | |
| axlDataDynamicReader (void) | |
| ~axlDataDynamicReader (void) | |
| axlAbstractData * | readInputs (axlDataDynamic *data, const QDomNode &node, const QList< axlAbstractData * > &list) |
| Construct an axlAbstractData from a node and a list of data. More... | |
| QString | identifier (void) const |
| QString | description (void) const |
| QStringList | handled (void) const |
| axlAbstractData * | dataByReader (axlAbstractDataReader *axl_reader, const QDomNode &node) |
| bool | accept (const QDomNode &node) |
| bool | reject (const QDomNode &node) |
| axlAbstractData * | read (const QDomNode &node) |
Public Member Functions inherited from axlAbstractDataReader | |
| axlAbstractDataReader (void) | |
| virtual | ~axlAbstractDataReader (void) |
| void | setNameOf (axlAbstractData *data, const QDomElement &e) |
| void | setColorOf (axlAbstractData *data, const QDomElement &e) |
| void | setSizeOf (axlAbstractData *data, const QDomElement &e) |
| void | setShaderOf (axlAbstractData *data, const QDomElement &e) |
Static Public Member Functions | |
| static bool | registered (void) |
Definition at line 26 of file axlDataDynamicReader.h.
| axlDataDynamicReader::axlDataDynamicReader | ( | void | ) |
Definition at line 37 of file axlDataDynamicReader.cpp.
| axlDataDynamicReader::~axlDataDynamicReader | ( | void | ) |
Definition at line 42 of file axlDataDynamicReader.cpp.
virtual |
Implements axlAbstractDataReader.
Definition at line 67 of file axlDataDynamicReader.cpp.
| axlAbstractData * axlDataDynamicReader::dataByReader | ( | axlAbstractDataReader * | axl_reader, |
| const QDomNode & | node | ||
Definition at line 422 of file axlDataDynamicReader.cpp.
| QString axlDataDynamicReader::description | ( | void | ) | const |
Definition at line 52 of file axlDataDynamicReader.cpp.
| QStringList axlDataDynamicReader::handled | ( | void | ) | const |
Definition at line 57 of file axlDataDynamicReader.cpp.
| QString axlDataDynamicReader::identifier | ( | void | ) | const |
Definition at line 47 of file axlDataDynamicReader.cpp.
virtual |
Definition at line 82 of file axlDataDynamicReader.cpp.
| axlAbstractData * axlDataDynamicReader::readInputs | ( | axlDataDynamic * | data, |
| const QDomNode & | node, | ||
| const QList< axlAbstractData * > & | list | ||
| data | : axlDataDynamic object to be constructed. |
| node | : node of the xml tree. |
| list | : list of data already constructed. |
The node should be of the form
where
process_name is the identifier of the process to be called.process_status is eitherdynamic for a dynamic data,static for a static data.<input ... />... corresponds to the list (possibly empty) of inputs of the process.<parameter ... />... corresponds to the list (possibly empty) of parameters of the process.<output ... />... corresponds to the list (possibly empty) of outputs of the process.The process will read its input, will setup its parameters and will compute outputs that will be stored in the objects described in the output list.
The input, parameter, output items have the following tags:
type="type_of_object" which can bedata for an axlAbstractData object specified by the tag name="...",double for a double value specified by the tag value="...",int for a int value specified by the tag value="...".name="name_of_an_object" to specify the name of the data to be used or to be computed.channel="an_integer" to specify which input or parameter channel is used.Here is an example of an input assigned to be the axlPoint data named axlPoint1 on channel 2:
The output items can have color and shader attributes to describe their rendering. Here is an example of an output which will be named "surface0" and will appear in red:
Definition at line 206 of file axlDataDynamicReader.cpp.
static |
Definition at line 62 of file axlDataDynamicReader.cpp.
virtual |
Definition at line 77 of file axlDataDynamicReader.cpp.
