#include <axlConeCreator.h>
Public Member Functions | |
| axlConeCreator (QObject *parent=0) | |
| virtual | ~axlConeCreator (void) |
| virtual axlAbstractData * | getInput (int channel) const |
| void | copyProcess (axlAbstractProcess *process) |
| bool | hasParameters (void) |
| virtual int | update (void) |
| virtual QString | description (void) const |
| virtual QString | identifier (void) const |
| virtual void | setInput (dtkAbstractData *newData, int channel) |
| virtual void | setParameter (double value) |
| virtual dtkAbstractData * | output (void) |
Public Member Functions inherited from axlAbstractCreatorProcess | |
| axlAbstractCreatorProcess (QObject *parent=0) | |
| virtual | ~axlAbstractCreatorProcess (void) |
| virtual dtkAbstractData * | output (int channel) |
| virtual int | channelCount (void) |
Public Member Functions inherited from axlAbstractProcess | |
| axlAbstractProcess (void) | |
| virtual | ~axlAbstractProcess (void) |
| virtual void | setDescription (QString description) |
| virtual void | setIdentifier (QString identifier) |
| virtual QString | form (void) const |
| Description of the form for the dialog with the process. More... | |
Static Public Member Functions | |
| static bool | registered (void) |
Definition at line 29 of file axlConeCreator.h.
| axlConeCreator::axlConeCreator | ( | QObject * | parent = 0 | ) |
Definition at line 39 of file axlConeCreator.cpp.
virtual |
Definition at line 48 of file axlConeCreator.cpp.
virtual |
Reimplemented from axlAbstractProcess.
Definition at line 64 of file axlConeCreator.cpp.
virtual |
Reimplemented from axlAbstractCreatorProcess.
Definition at line 120 of file axlConeCreator.cpp.
virtual |
Definition at line 55 of file axlConeCreator.cpp.
virtual |
returns true if the process needs parameters. By default, equals false.
Definition at line 71 of file axlConeCreator.cpp.
virtual |
Definition at line 125 of file axlConeCreator.cpp.
virtual |
Definition at line 77 of file axlConeCreator.cpp.
static |
Definition at line 129 of file axlConeCreator.cpp.
virtual |
Definition at line 81 of file axlConeCreator.cpp.
virtual |
Definition at line 93 of file axlConeCreator.cpp.
virtual |
Definition at line 98 of file axlConeCreator.cpp.
