Class axlCircleArcCreator defines an process which creates an axlCircleArc. More...
#include <axlCircleArcCreator.h>
 Public Member Functions | |
| axlCircleArcCreator (QObject *parent=0) | |
| virtual | ~axlCircleArcCreator (void) |
| virtual axlAbstractData * | getInput (int channel) const |
| Return the input points of the process.  More... | |
| void | copyProcess (axlAbstractProcess *process) |
| Return a copy of the process, useful for dynamic objects.  More... | |
| bool | hasParameters (void) |
| Return true as the process needs one parameter.  More... | |
| virtual int | update (void) |
| Create an axlCircleArc.  More... | |
| virtual QString | description (void) const |
| virtual QString | identifier (void) const |
| virtual void | setInput (dtkAbstractData *newData, int channel) |
| Assigns points :  More... | |
| virtual void | setParameter (int data) |
| Assigns the value of the boolean parameter which says whether it is direct .  More... | |
| virtual dtkAbstractData * | output (void) |
| Return the results of the process : NULL or the axlCircleArc.  More... | |
  Public Member Functions inherited from axlAbstractCreatorProcess | |
| axlAbstractCreatorProcess (QObject *parent=0) | |
| virtual | ~axlAbstractCreatorProcess (void) |
| virtual dtkAbstractData * | output (int channel) |
| virtual int | channelCount (void) |
  Public Member Functions inherited from axlAbstractProcess | |
| axlAbstractProcess (void) | |
| virtual | ~axlAbstractProcess (void) |
| virtual void | setDescription (QString description) |
| virtual void | setIdentifier (QString identifier) |
| virtual QString | form (void) const |
| Description of the form for the dialog with the process.  More... | |
Example:
Definition at line 30 of file axlCircleArcCreator.h.
| axlCircleArcCreator::axlCircleArcCreator | ( | QObject * | parent = 0 | ) |
Definition at line 39 of file axlCircleArcCreator.cpp.
  virtual |
Definition at line 48 of file axlCircleArcCreator.cpp.
  virtual |
Reimplemented from axlAbstractProcess.
Definition at line 79 of file axlCircleArcCreator.cpp.
  virtual |
Reimplemented from axlAbstractCreatorProcess.
Definition at line 161 of file axlCircleArcCreator.cpp.
  virtual |
channel = 0, return the first extreme point . channel = 1, return the second extreme point channel = 2, return the center of the circle arc channel = 3, return the normal of the plan that conatins the circle arc.
Definition at line 61 of file axlCircleArcCreator.cpp.
  virtual |
Definition at line 89 of file axlCircleArcCreator.cpp.
  virtual |
Definition at line 166 of file axlCircleArcCreator.cpp.
  virtual |
Definition at line 97 of file axlCircleArcCreator.cpp.
  virtual |
Assigns points :
channel = 0, the first extreme point . channel = 1, the second extreme point channel = 2, the center of the circle arc channel = 3, the normal of the plan that conatins the circle arc.
Definition at line 108 of file axlCircleArcCreator.cpp.
  virtual |
Definition at line 129 of file axlCircleArcCreator.cpp.
  virtual |
Definition at line 140 of file axlCircleArcCreator.cpp.
