addField(axlAbstractField *field) | axlAbstractData | |
axlAbstractCurve(void) | axlAbstractCurve | |
axlAbstractCurveBSpline(void) | axlAbstractCurveBSpline | |
axlAbstractCurveNurbs(void) | axlAbstractCurveNurbs | |
axlAbstractCurveParametric(void) | axlAbstractCurveParametric | |
axlAbstractData(axlAbstractData *parent=NULL) | axlAbstractData | |
axlAbstractData(const axlAbstractData &data) | axlAbstractData | |
changeFieldName(QString fieldName) | axlAbstractData | |
closestParameter(const axlPoint &pt) | axlAbstractCurveBSpline | virtual |
closestPoint(const axlPoint &pt) | axlAbstractCurveBSpline | virtual |
color | axlAbstractData | |
color(void) const | axlAbstractData | |
connectionsAreDefined(void) | axlAbstractCurveBSpline | virtual |
convertDataToQVariant(void) const | axlAbstractCurveBSpline | virtual |
convertQVariantToData(const QVariantList &data) | axlAbstractCurveBSpline | virtual |
countControlPoints(void) const | axlAbstractCurveBSpline | virtual |
curve(void) | axlAbstractCurve | virtual |
defineControlPointConnection(int i, int j) | axlAbstractCurveBSpline | virtual |
description(void) const | axlAbstractCurveBSpline | virtual |
dimension(void) const | axlAbstractCurve | virtual |
editable(void) | axlAbstractData | |
endParam(void) | axlAbstractCurveBSpline | virtual |
eval(double u) | axlAbstractCurveParametric | virtual |
eval(axlPoint *point, double u) | axlAbstractCurveParametric | virtual |
eval(double u, int derivs, bool from_right=true) | axlAbstractCurveParametric | virtual |
fields(void) | axlAbstractData | |
getCoef(int n) const | axlAbstractCurveBSpline | virtual |
getControlPointConnection(int i) | axlAbstractCurveBSpline | virtual |
getKnot(int n) const | axlAbstractCurveBSpline | virtual |
getWeight(int n) const | axlAbstractCurveBSpline | virtual |
indexSelected(int) | axlAbstractCurveBSpline | signal |
insertKnot(double k) | axlAbstractCurveBSpline | virtual |
isPlanar(void) const | axlAbstractCurve | virtual |
knotVectorSize(void) const | axlAbstractCurveBSpline | virtual |
length(double tolerance) | axlAbstractCurveParametric | virtual |
mesh(void) | axlAbstractData | |
modifiedField(void) | axlAbstractData | signal |
modifiedGeometry(void) | axlAbstractData | signal |
modifiedProperty(void) | axlAbstractData | signal |
modifiedStructure(void) | axlAbstractData | signal |
numCoefs() const | axlAbstractCurveBSpline | virtual |
numSamples(void) | axlAbstractCurveParametric | virtual |
onDirectChanged(bool direct) | axlAbstractCurveParametric | virtualslot |
opacity | axlAbstractData | |
opacity(void) const | axlAbstractData | |
order(void) const | axlAbstractCurveBSpline | virtual |
parameterOf(const axlPoint &p) | axlAbstractCurveParametric | |
printCoeffs(bool print) const | axlAbstractCurveBSpline | virtual |
printKnotsVector(bool print) const | axlAbstractCurveBSpline | virtual |
rational(void) const | axlAbstractCurveBSpline | virtual |
removeKnot(double k) | axlAbstractCurveBSpline | virtual |
resetControlPointConnections(void) | axlAbstractCurveBSpline | virtual |
Sample typedef | axlAbstractCurveBSpline | |
samples | axlAbstractCurveParametric | |
samples(void) const | axlAbstractCurveParametric | |
sampling(int n) | axlAbstractCurveBSpline | virtual |
samplingChanged() | axlAbstractCurveBSpline | signal |
selectIndex(int i) | axlAbstractCurveBSpline | inlinevirtual |
setCoef(int n, double *controlPoint) | axlAbstractCurveBSpline | virtual |
setColor(double r, double g, double b) | axlAbstractData | |
setColor(const QColor &color) | axlAbstractData | slot |
setCurve(int pointsCount, int order, int dimension, double *knots, double *points, bool rational) | axlAbstractCurveBSpline | virtual |
setEditable(bool edit) | axlAbstractData | slot |
setMesh(axlMesh *mesh) | axlAbstractData | |
setNumSamples(int numSamples) | axlAbstractCurveParametric | virtual |
setOpacity(const double &opacity) | axlAbstractData | slot |
setSamples(const int &color) | axlAbstractCurveParametric | slot |
setShader(const QString &shader) | axlAbstractData | slot |
setSize(const double &size) | axlAbstractData | slot |
setUpdateView(bool updateView) | axlAbstractData | |
shader | axlAbstractData | |
shader(void) const | axlAbstractData | |
size | axlAbstractData | |
size(void) const | axlAbstractData | |
startParam(void) | axlAbstractCurveBSpline | virtual |
touchField(void) | axlAbstractData | virtualslot |
touchGeometry(void) | axlAbstractData | slot |
touchProperty(void) | axlAbstractData | slot |
touchStructure(void) | axlAbstractData | slot |
updated(void) | axlAbstractCurveBSpline | signal |
updateFieldList(QString nameField) | axlAbstractData | |
updateRcoeff() | axlAbstractCurveBSpline | virtual |
updateView(void) | axlAbstractData | |
~axlAbstractCurve(void) | axlAbstractCurve | virtual |
~axlAbstractCurveBSpline(void) | axlAbstractCurveBSpline | virtual |
~axlAbstractCurveNurbs(void) | axlAbstractCurveNurbs | virtual |
~axlAbstractCurveParametric(void) | axlAbstractCurveParametric | virtual |
~axlAbstractData(void) | axlAbstractData | virtual |
