17 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
   21 #include <vtkImageData.h>
   22 #include <vtkIdList.h>
   24 #include <vtkPoints.h>
   37 class axlVolumeDiscreteConverterPrivate
   60     return "axlVolumeDiscreteConverter";
   65     return "Converter from axlVolume to axlMesh";
   70     return QStringList() <<
"axlVolumeDiscreteConverter" <<
"axlVolume" ;
   89     vtkImageData *grid =
static_cast<vtkImageData *
>(d->data->data());
   92     QVector<axlPoint *> listPoints;
   93     int nbPoints = grid->GetNumberOfPoints();
   95     for(
int i = 0; i <nbPoints;i++){
  103     QVector<int> listFaces;
  104     QVector<int> listEdges;
  106     vtkCell *currentCell;
  107     vtkCell *currentFace;
  108     vtkCell *currentEdge;
  120     int nbCells = grid->GetNumberOfCells();
  121     for(
int ic = 0 ; ic < nbCells ; ic++){
  122         currentCell  = grid->GetCell(ic);
  123         faces = currentCell->GetNumberOfFaces();
  124         edges = currentCell->GetNumberOfEdges();
  127         for(
int jf= 0 ;jf < faces;jf++){
  128             currentFace = currentCell->GetFace(jf);
  129             list = currentFace->GetPoints();
  130             points = list->GetNumberOfPoints();
  131             if(!listFaces.empty()){
  134             for (
int jp = 0; jp < points; jp ++){
  135                 id = currentFace->GetPointId(jp);
  136                 listFaces.append(
id);
  139             std::vector<int> vectorFace = listFaces.toStdVector();
  140             std::sort (vectorFace.begin(), vectorFace.end());
  141             listFaces = QVector<int>::fromStdVector(vectorFace);
  142             first = listFaces.first();
  143             second = listFaces.at(1);
  144             third = listFaces.at(2);
  145             last = listFaces.last();
  152         for(
int je= 0 ;je < edges;je++){
  153             currentEdge = currentCell->GetEdge(je);
  154             list = currentEdge->GetPoints();
  155             points = list->GetNumberOfPoints();
  156             if(!listEdges.empty()){
  159             for (
  160                 id = currentEdge->GetPointId(jp);
  161                 listEdges.append(
id);
static bool registered(void)
Class axlPoint defines 3D points.
void noDuplicateVertices(void)
Remove duplicated vertices.
void setData(dtkAbstractData *data)
QStringList fromTypes(void) const
void push_back_edge(int, int)
QString description(void) const
axlVolumeDiscreteConverter(void)
QString identifier(void) const
~axlVolumeDiscreteConverter(void)
void setVertices(const QVector< axlPoint * > &pointSet)
void push_back_face(const Face &face)
dtkAbstractDataConverter * createaxlVolumeDiscreteConverter(void)
QString toType(void) const
static dtkAbstractDataFactory * dataFactSingleton
Class axlMesh defines a piecewise-linear 3D object.
