24 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
   26 class axlSurfaceParametricOffsetConverterPrivate
   46     return "Converter from axlSurfaceParametricOffsetConverter to axlMesh";
   51     return "axlSurfaceParametricOffsetConverter";
   56     return QStringList() <<
"axlSurfaceParametricOffsetConverter" <<
"axlSurfaceParametricOffset";
   75     double uMin = d->data->surfaceParam()->startParam_u();
   76     double uMax = d->data->surfaceParam()->endParam_u();
   77     double vMin = d->data->surfaceParam()->startParam_v();
   78     double vMax = d->data->surfaceParam()->endParam_v();
   79     double stepu = (uMax-uMin)/40;
   80     double stepv = (vMax-vMin)/40;
   82     for(
double u=uMin ;u < uMax ;u+=stepu ){
   83        for(
double v=vMin ;v < vMax ;v+=stepv){
   86           d->data->surfaceParam()->normal(currentNormal, u, v);
   87           d->data->surfaceParam()->eval(currentEval, u,v);
   89            axlPoint *currentResult =
new axlPoint(*currentEval + *currentNormal * d->data->offset());
  103     for(
int j = 0; j < n_v - 1; j++) {
  105         for(
int i= 0; i <n_u - 1; i++) {
  110             QVector<int> firstTriangle;
  111             QVector<int> secondTriamgle;
  113             firstTriangle.push_back(ind1);
  114             firstTriangle.push_back(ind1 + 1);
  115             firstTriangle.push_back(ind2);
  117             secondTriamgle.push_back(ind2);
  118             secondTriamgle.push_back(ind1 + 1);
  119             secondTriamgle.push_back(ind2 + 1);
Class axlPoint defines 3D points.
QString identifier(void) const
void setShader(const QString &shader)
QString description(void) const
Class axlSurfaceParametricOffset defines offset of axlAbstractSurfaceParametric.
~axlSurfaceParametricOffsetConverter(void)
QStringList fromTypes(void) const
dtkAbstractDataConverter * createaxlSurfaceParametricOffsetConverter(void)
void push_back_face(const Face &face)
void setOpacity(const double &opacity)
void setColor(double r, double g, double b)
void setData(dtkAbstractData *data)
QString toType(void) const
static bool registered(void)
Class axlMesh defines a piecewise-linear 3D object.
void push_back_vertex(const double &x, const double &y, const double &z)
Add a new vertex to the mesh.
