26 #include <dtkCoreSupport/dtkGlobal.h>
   30 class axlInspectorObjectSceneWidgetFieldScalarIsoPrivate
   37           QSpinBox *iso_count_spin;
   38     QDoubleSpinBox *iso_radius_spin;
   39     QDoubleSpinBox *iso_range_min_spin;
   40     QDoubleSpinBox *iso_range_max_spin;
   41        QPushButton *button_reset_min;
   42        QPushButton *button_reset_max;
   50     QWidget *iso_form =
new QWidget(
this);
   51     iso_form->setObjectName(
"axlInspectorObjectSceneWidgetFieldScalarIsoForm");
   53     QWidget *iso_form_range_min =
new QWidget(iso_form);
   54     QWidget *iso_form_range_max =
   56     d->iso_count_spin =
new QSpinBox(iso_form); d->iso_count_spin->setMaximum(1000);
   58     d->iso_radius_spin =
new QDoubleSpinBox(iso_form);
   59      d->iso_radius_spin->setValue(0.01);
   60     d->iso_radius_spin->setMaximum(1000);
   61     d->iso_radius_spin->setMinimum(0.0);
   62     d->iso_radius_spin->setDecimals(5);
   63     d->iso_radius_spin->setSingleStep(0.01);
   65     d->iso_range_min_spin =
   66     d->iso_range_min_spin->setDecimals(5);
   67     d->iso_range_min_spin->setMinimum(-1.e6);
   68     d->iso_range_min_spin->setMaximum(1.e6);
   71     d->iso_range_max_spin =
   72     d->iso_range_max_spin->setDecimals(5);
   73     d->iso_range_max_spin->setMinimum(-1.e6);
   74     d->iso_range_max_spin->setMaximum(1.e6);
   77     d->button_reset_min =
new QPushButton(
"reset", iso_form);
   78     d->button_reset_max =
new QPushButton(
"reset", iso_form);
   80     QHBoxLayout *iso_form_range_min_layout =
new QHBoxLayout(iso_form_range_min);
   81     iso_form_range_min_layout->setContentsMargins(0, 0, 0, 0);
   82     iso_form_range_min_layout->addWidget(d->iso_range_min_spin);
   83     iso_form_range_min_layout->addWidget(d->button_reset_min);
   85     QHBoxLayout *iso_form_range_max_layout =
new QHBoxLayout(iso_form_range_max);
   86     iso_form_range_max_layout->setContentsMargins(0, 0, 0, 0);
   87     iso_form_range_max_layout->addWidget(d->iso_range_max_spin);
   88     iso_form_range_max_layout->addWidget(d->button_reset_max);
   90     QFormLayout *iso_form_layout =
new QFormLayout(iso_form);
   91     iso_form_layout->setFieldGrowthPolicy(QFormLayout::AllNonFixedFieldsGrow);
   92     iso_form_layout->setContentsMargins(0, 0, 0, 0);
   93     iso_form_layout->addRow(
"Number of contours:", d->iso_count_spin);
   94     iso_form_layout->addRow(
"Radius of tubes:", d->iso_radius_spin);
   95     iso_form_layout->addRow(
new QLabel(
"Range",
this));
   96     iso_form_layout->addRow(
"Minimum value:", iso_form_range_min);
   97     iso_form_layout->addRow(
"Maximum value:", iso_form_range_max);
   99     QVBoxLayout *layout =
new QVBoxLayout(
this);
  100     layout->setContentsMargins(0, 0, 0, 0);
  101     layout->addWidget(
new QLabel(
"Iso contours",
this));
  102     layout->addWidget(iso_form);
  105     connect(d->iso_count_spin, SIGNAL(valueChanged(
int)),
this, SIGNAL(
isoCountChanged(
int)));
  106     connect(d->iso_radius_spin, SIGNAL(valueChanged(
double)),
this, SIGNAL(
isoRadiusChanged(
double)));
  107     connect(d->iso_range_min_spin, SIGNAL(valueChanged(
double)),
this, SIGNAL(
isoRangeMinChanged(
double)));
  109     connect(d->iso_range_max_spin, SIGNAL(valueChanged(
double)),
this, SIGNAL(
isoRangeMaxChanged(
double)));
  122     d->iso_count_spin->setValue(count);
  127     d->iso_range_min_spin->setValue(min);
  132     d->iso_range_max_spin->setValue(max);
  145         this->
setMax(actor->isoRangeMax());
  146         this->
setMin(actor->isoRangeMin());
  160         this->
  161         this->
  167     this->
setMin(d->field->minValue());
  172     this->
setMax(d->field->maxValue());
Class axlAbstractField defines an API for arrays of numeric data.
