26 #include <dtkCoreSupport/dtkGlobal.h>
   30 class axlInspectorObjectSceneWidgetFieldScalarColPrivate
   37           QSpinBox *col_count_spin;
   38     QDoubleSpinBox *col_range_min_spin;
   39     QDoubleSpinBox *col_range_max_spin;
   40        QPushButton *button_reset_min;
   41        QPushButton *button_reset_max;
   49     QWidget *col_form =
new QWidget(
this);
   50     col_form->setObjectName(
"axlInspectorObjectSceneWidgetFieldScalarColForm");
   52     QWidget *col_form_range_min =
new QWidget(col_form);
   53     QWidget *col_form_range_max =
   55     d->col_range_min_spin =
new QDoubleSpinBox(col_form);
   56     d->col_range_min_spin->setDecimals(6);
   57     d->col_range_min_spin->setMinimum(-1.e6);
   58     d->col_range_min_spin->setMaximum(1.e6);
   60     d->col_range_max_spin =
   61     d->col_range_max_spin->setDecimals(6);
   62     d->col_range_max_spin->setMinimum(-1.e6);
   63     d->col_range_max_spin->setMaximum(1.e6);
   65     d->button_reset_min =
new QPushButton(
"reset", col_form);
   66     d->button_reset_max =
new QPushButton(
"reset", col_form);
   68     QHBoxLayout *col_form_range_min_layout =
new QHBoxLayout(col_form_range_min);
   69     col_form_range_min_layout->setContentsMargins(0, 0, 0, 0);
   70     col_form_range_min_layout->addWidget(d->col_range_min_spin);
   71     col_form_range_min_layout->addWidget(d->button_reset_min);
   73     QHBoxLayout *col_form_range_max_layout =
new QHBoxLayout(col_form_range_max);
   74     col_form_range_max_layout->setContentsMargins(0, 0, 0, 0);
   75     col_form_range_max_layout->addWidget(d->col_range_max_spin);
   76     col_form_range_max_layout->addWidget(d->button_reset_max);
   78     QFormLayout *col_form_layout =
new QFormLayout(col_form);
   79     col_form_layout->setFieldGrowthPolicy(QFormLayout::AllNonFixedFieldsGrow);
   80     col_form_layout->setContentsMargins(0, 0, 0, 0);
   81     col_form_layout->addRow(
new QLabel(
"Range",
this));
   82     col_form_layout->addRow(
"Minimum value:", col_form_range_min);
   83     col_form_layout->addRow(
"Maximum value:", col_form_range_max);
   85     QVBoxLayout *layout =
new QVBoxLayout(
this);
   86     layout->setContentsMargins(0, 0, 0, 0);
   87     layout->addWidget(col_form);
   90     connect(d->col_range_min_spin, SIGNAL(valueChanged(
double)),
this, SIGNAL(
colRangeMinChanged(
double)));
   92     connect(d->col_range_max_spin, SIGNAL(valueChanged(
double)),
this, SIGNAL(
colRangeMaxChanged(
double)));
  105     d->col_range_min_spin->setValue(min);
  110     d->col_range_max_spin->setValue(max);
  121         this->
setMax(actor->colRangeMax());
  122         this->
setMin(actor->colRangeMin());
  134         this->
  135         this->
  141     this->
setMin(d->field->minValue());
  146     this->
setMax(d->field->maxValue());
Class axlAbstractField defines an API for arrays of numeric data.
