19 #include <dtkCoreSupport/dtkAbstractData.h>
   20 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
   38     return "axlFieldSpatialCoordinatesWriter";
   43     return "axlFieldSpatialCoordinatesWriter";
   48     return QStringList() <<
"axlAbstractField" <<
"axlAbstractFieldSpatial" <<
"axlFieldSpatialCoordinates";
   67     return !this->
accept(data);
   74     QDomElement fieldElement = doc->createElement(
"field");
   77     fieldElement.setAttribute(
"type", field->
identifier());
   80     for(
int i = 0; i < 3;i++){
   82         QDomElement parameter = doc->createElement(
"parameter");
   83         parameter.setAttribute(
"value", QString::number(field->
parameter(i)));
   84         parameter.setAttribute(
"channel", QString::number(i));
   85         parameter.setAttribute(
"type",
"double");
   86         fieldElement.appendChild(parameter);
   95 QDomElement axlFieldSpatialCoordinatesWriter::elementByWriter(
axlAbstractDataWriter *axl_writer, QDomDocument *doc, dtkAbstractData *data)
  102     if(!axl_writer->
accept(data))
  105     element = axl_writer->
write(doc, data);
axlFieldSpatialCoordinatesWriter(void)
QStringList handled(void) const
virtual bool accept(dtkAbstractData *data)=0
QString description(void) const
Class axlFieldSpatialCoordinates defines an API for spatial field. The value are computed as follow :...
QString identifier(void) const
Returns the identifier of the field which is "axlFieldSpatialCoordinates".
static bool registered(void)
bool reject(dtkAbstractData *data)
double parameter(int channel)
Returns the channel-th parameter value.
~axlFieldSpatialCoordinatesWriter(void)
QDomElement write(QDomDocument *doc, dtkAbstractData *data)
virtual QDomElement write(QDomDocument *doc, dtkAbstractData *data)=0
dtkAbstractDataWriter * createaxlFieldSpatialCoordinatesWriter(void)
