Go to the source code of this file.
Classes | |
| class | axlFieldSpatialCoordinates |
| Class axlFieldSpatialCoordinates defines an API for spatial field. The value are computed as follow : this->scalar(x,y,z) returns a*x+b*y+c*z value with (a,b,c) the direction chosen. By default this direction is equal to (0,0,1). More... | |
Functions | |
| AXLCORE_EXPORT dtkAbstractData * | createaxlFieldSpatialCoordinates (void) |
| AXLCORE_EXPORT dtkAbstractData* createaxlFieldSpatialCoordinates | ( | void | ) |
Definition at line 171 of file axlFieldSpatialCoordinates.cpp.
