This is the complete list of members for axlShape, including all inherited members.
| addField(axlAbstractField *field) | axlAbstractData | |
| axlAbstractData(axlAbstractData *parent=NULL) | axlAbstractData | |
| axlAbstractData(const axlAbstractData &data) | axlAbstractData | |
| axlShape(int vertexCount, int edgeCount, int faceCount, axlShape *parent=0) | axlShape | |
| changeFieldName(QString fieldName) | axlAbstractData | |
| color | axlAbstractData | |
| color(void) const | axlAbstractData | |
| convertDataToQVariant(void) const | axlShape | virtual |
| convertQVariantToData(const QVariantList &data) | axlShape | virtual |
| description(void) const | axlShape | virtual |
| editable(void) | axlAbstractData | |
| fields(void) | axlAbstractData | |
| getEdgeCount(void) const | axlShape | |
| getEdges(void) const | axlShape | |
| getFaceCount(void) const | axlShape | |
| getFaces(void) const | axlShape | |
| getVertexCount(void) const | axlShape | |
| getVertices(void) const | axlShape | |
| identifier(void) const | axlShape | virtual |
| insert_edge(Edge *edge, int index) | axlShape | |
| insert_edge(axlAbstractCurveParametric *crv, int si, int ei, int index) | axlShape | |
| insert_face(Face *face, int index) | axlShape | |
| insert_face(axlAbstractSurfaceParametric *surf, int *l, int *orient, int *loopsSize, int sizel, int nbLoops, int index) | axlShape | |
| insert_face(axlAbstractSurfaceParametric *surf, int *l, int *orient, int sizel, int sizeOrient, int index) | axlShape | |
| insert_face_with_no_sort(axlAbstractSurfaceParametric *surf, int *l, int *orient, int sizel, int sizeOrient, int index) | axlShape | |
| insert_face_with_no_sort(axlAbstractSurfaceParametric *surf, int *l, int *orient, int *loopsSize, int sizel, int nbLoops, int index) | axlShape | |
| insert_vertex(axlPoint *vertex, int index) | axlShape | |
| mesh(void) | axlAbstractData | |
| modifiedField(void) | axlAbstractData | signal |
| modifiedGeometry(void) | axlAbstractData | signal |
| modifiedProperty(void) | axlAbstractData | signal |
| modifiedStructure(void) | axlAbstractData | signal |
| opacity | axlAbstractData | |
| opacity(void) const | axlAbstractData | |
| setColor(double r, double g, double b) | axlAbstractData | |
| setColor(const QColor &color) | axlAbstractData | slot |
| setEditable(bool edit) | axlAbstractData | slot |
| setMesh(axlMesh *mesh) | axlAbstractData | |
| setOpacity(const double &opacity) | axlAbstractData | slot |
| setShader(const QString &shader) | axlAbstractData | slot |
| setSize(const double &size) | axlAbstractData | slot |
| setUpdateView(bool updateView) | axlAbstractData | |
| shader | axlAbstractData | |
| shader(void) const | axlAbstractData | |
| size | axlAbstractData | |
| size(void) const | axlAbstractData | |
| sortEdges(Loop *loop) | axlShape | |
| sortLoops(Face *face) | axlShape | |
| touchField(void) | axlAbstractData | virtualslot |
| touchGeometry(void) | axlAbstractData | slot |
| touchProperty(void) | axlAbstractData | slot |
| touchStructure(void) | axlAbstractData | slot |
| updateFieldList(QString nameField) | axlAbstractData | |
| updateView(void) | axlAbstractData | |
| ~axlAbstractData(void) | axlAbstractData | virtual |
| ~axlShape(void) | axlShape | virtual |
