Developer documentation | Axl-2.5.1
axlOFFReader Class Reference
#include <axlOFFReader.h>
Inheritance diagram for axlOFFReader:
Public Slots
bool canRead (const QString &file)
 Check that the file can be read by this type of reader. More...
bool read (const QString &file)
 Read the file which is supposed to be of right type OFF and create a data. More...
Public Member Functions
 axlOFFReader (void)
 ~axlOFFReader (void)
QString identifier (void) const
 Return the identifier "axlOFFReader". More...
QString description (void) const
 Return a description of the reader. More...
QStringList handled (void) const
 Return the type of file that the reader is able to read : "OFF files (.OFF, .off)" . More...
Static Public Member Functions
static bool registered (void)
 Register this reader type in the factory. More...
Detailed Description
Definition at line 24 of file axlOFFReader.h.
Constructor & Destructor Documentation
axlOFFReader::axlOFFReader ( void  )
Definition at line 28 of file axlOFFReader.cpp.
axlOFFReader::~axlOFFReader ( void  )
Definition at line 33 of file axlOFFReader.cpp.
Member Function Documentation
bool axlOFFReader::canRead ( const QString &  file)
slot
Definition at line 83 of file axlOFFReader.cpp.
QString axlOFFReader::description ( void  ) const
Definition at line 53 of file axlOFFReader.cpp.
QStringList axlOFFReader::handled ( void  ) const
Definition at line 63 of file axlOFFReader.cpp.
QString axlOFFReader::identifier ( void  ) const
Definition at line 43 of file axlOFFReader.cpp.
bool axlOFFReader::read ( const QString &  file)
slot
Return true if the data is correctly created, else return false.
Definition at line 109 of file axlOFFReader.cpp.
bool axlOFFReader::registered ( void  )
static
Definition at line 73 of file axlOFFReader.cpp.
The documentation for this class was generated from the following files:
