| addField(axlAbstractField *field) | axlAbstractData | |
| all_edge_count(void) const | axlMesh | |
| append(axlMesh *mesh) | axlMesh | |
| axlAbstractData(axlAbstractData *parent=NULL) | axlAbstractData | |
| axlAbstractData(const axlAbstractData &data) | axlAbstractData | |
| axlMesh(void) | axlMesh | |
| boundingBoxVertex(void) const | axlMesh | |
| changeFieldName(QString fieldName) | axlAbstractData | |
| clearNormals(void) | axlMesh | |
| color | axlAbstractData | |
| color(void) const | axlAbstractData | |
| color_count(void) const | axlMesh | |
| color_used(void) const | axlMesh | |
| color_used(void) | axlMesh | |
| colorB(const int &ind) | axlMesh | |
| colorBF(const int &ind) | axlMesh | |
| colorG(const int &ind) | axlMesh | |
| colorGF(const int &ind) | axlMesh | |
| colorR(const int &ind) | axlMesh | |
| colorRF(const int &ind) | axlMesh | |
| convertDataToQVariant(void) const | axlMesh | virtual |
| convertQVariantToData(const QVariantList &data) | axlMesh | virtual |
| description(void) const | axlMesh | virtual |
| distance(int ind1, int ind2) | axlMesh | |
| Edge typedef | axlMesh | |
| edge(int ind) const | axlMesh | |
| edge_show(void) const | axlMesh | |
| edge_show(void) | axlMesh | |
| edgePointCount(int i) const | axlMesh | |
| edgePointIndex(int i, int j) const | axlMesh | |
| edgePushBack(int, int) | axlMesh | |
| edgeSet(void) const | axlMesh | |
| editable(void) | axlAbstractData | |
| espilon(void) | axlMesh | |
| Face typedef | axlMesh | |
| face(int ind) const | axlMesh | |
| face_count(void) const | axlMesh | |
| face_show(void) const | axlMesh | |
| face_show(void) | axlMesh | |
| facePointCount(int i) const | axlMesh | |
| facePointIndex(int i, int j) const | axlMesh | |
| faceSet(void) const | axlMesh | |
| fields(void) | axlAbstractData | |
| FLAT enum value | axlMesh | |
| getColor(const int &ind, int color[3]) | axlMesh | |
| GOURAUD enum value | axlMesh | |
| identifier(void) const | axlMesh | virtual |
| insert_face(const Face &face) | axlMesh | inline |
| Intepolation enum name | axlMesh | |
| interpolation(void) const | axlMesh | |
| isPlanar(void) const | axlMesh | |
| isPlanar(void) | axlMesh | |
| mesh(void) | axlAbstractData | |
| meshVertexScaleFactor() const | axlMesh | |
| modifiedField(void) | axlAbstractData | signal |
| modifiedGeometry(void) | axlAbstractData | signal |
| modifiedProperty(void) | axlAbstractData | signal |
| modifiedStructure(void) | axlAbstractData | signal |
| neighborsFace(const axlMesh &mesh) | axlMesh | static |
| noDuplicateVertices(void) | axlMesh | |
| normal(const int &ind, double normal[3]) | axlMesh | |
| normal(int ind, axlPoint &normal) | axlMesh | |
| normal(int ind, axlPoint *normal) | axlMesh | |
| normal2(int ind, axlPoint *normal) | axlMesh | |
| normal_count(void) const | axlMesh | |
| normal_used(void) const | axlMesh | |
| normal_used(void) | axlMesh | |
| normalSet(void) | axlMesh | |
| normalX(const int &ind) const | axlMesh | |
| normalY(const int &ind) const | axlMesh | |
| normalZ(const int &ind) const | axlMesh | |
| opacity | axlAbstractData | |
| opacity(void) const | axlAbstractData | |
| operator[](int i) | axlMesh | |
| PHONG enum value | axlMesh | |
| Point typedef | axlMesh | |
| push_back_color(const int &r, const int &g, const int &b) | axlMesh | |
| push_back_color(const int color[3]) | axlMesh | |
| push_back_edge(int, int) | axlMesh | |
| push_back_edge(const Edge &e) | axlMesh | |
| push_back_face(const Face &face) | axlMesh | |
| push_back_face(int i1, int i2, int i3) | axlMesh | |
| push_back_new_edge(void) | axlMesh | |
| push_back_normal(axlPoint *normal) | axlMesh | |
| push_back_normal(const double &x, const double &y, const double &z) | axlMesh | |
| push_back_normal(const double normal[3]) | axlMesh | |
| push_back_vertex(const double &x, const double &y, const double &z) | axlMesh | |
| push_back_vertex(const double vertex[3]) | axlMesh | |
| push_back_vertex(const axlPoint &vertex) | axlMesh | |
| push_back_vertex(axlPoint *vertex) | axlMesh | |
| set_vertex(axlPoint *point, const int &ind) | axlMesh | |
| setColor(double r, double g, double b) | axlAbstractData | |
| setColor(const QColor &color) | axlAbstractData | slot |
| setEditable(bool edit) | axlAbstractData | slot |
| setEpsilon(double epsilon) | axlMesh | |
| setInterpolation(int interpolation) | axlMesh | |
| setMesh(axlMesh *mesh) | axlAbstractData | |
| setNormals(const QList< axlPoint * > &pointSet) | axlMesh | |
| setOpacity(const double &opacity) | axlAbstractData | slot |
| setShader(const QString &shader) | axlAbstractData | slot |
| setSize(const double &size) | axlAbstractData | slot |
| setUpdateView(bool updateView) | axlAbstractData | |
| setVertices(const QVector< axlPoint * > &pointSet) | axlMesh | |
| shader | axlAbstractData | |
| shader(void) const | axlAbstractData | |
| size | axlAbstractData | |
| size(void) const | axlAbstractData | |
| touchField(void) | axlAbstractData | virtualslot |
| touchGeometry(void) | axlAbstractData | slot |
| touchProperty(void) | axlAbstractData | slot |
| touchStructure(void) | axlAbstractData | slot |
| updateFieldList(QString nameField) | axlAbstractData | |
| updateView(void) | axlAbstractData | |
| vertex(const int &ind, double vertex[3]) | axlMesh | |
| vertex(int ind, axlPoint &point) const | axlMesh | |
| vertex(int ind, axlPoint *point) const | axlMesh | |
| vertex2(int ind, axlPoint *point) const | axlMesh | |
| vertex_count(void) const | axlMesh | |
| vertex_show(void) const | axlMesh | |
| vertex_show() | axlMesh | |
| vertexSet(void) const | axlMesh | |
| VertexTofaceIndexes(const axlMesh &mesh) | axlMesh | static |
| vertexX(const int &ind) const | axlMesh | |
| vertexY(const int &ind) const | axlMesh | |
| vertexZ(const int &ind) const | axlMesh | |
| ~axlAbstractData(void) | axlAbstractData | virtual |
| ~axlMesh(void) | axlMesh | |
