Developer documentation | Axl-2.5.1
axlLightsWidget Class Reference
#include <axlLightsWidget.h>
Inheritance diagram for axlLightsWidget:
Public Member Functions
 vtkTypeMacro (axlLightsWidget, vtk3DWidget)
void PrintSelf (ostream &os, vtkIndent indent)
void PlaceWidget (double bounds[6])
void PlaceWidget (void)
void PlaceWidget (double xmin, double xmax, double ymin, double ymax, double zmin, double zmax)
void SetEnabled (int)
void initializePoints (void)
void resetProperty (void)
void update ()
vtkActor * netActor (void)
vtkActorCollection * ptsActors (void)
void setView (axlAbstractView *view)
Static Public Member Functions
static axlLightsWidgetNew ()
Protected Types
enum  WidgetState {
  Start, Moving, Scaling, Translating,
  Outside
Protected Member Functions
 axlLightsWidget ()
 ~axlLightsWidget (void)
int HighlightHandle (vtkProp *prop)
virtual void OnMouseMove (void)
virtual void OnLeftButtonDown (void)
virtual void OnLeftButtonUp (void)
void CreateDefaultProperties (void)
Static Protected Member Functions
static void ProcessEvents (vtkObject *object, unsigned long event, void *clientdata, void *calldata)
Protected Attributes
int State
Detailed Description
Definition at line 43 of file axlLightsWidget.h.
Member Enumeration Documentation
Enumerator
Start
Moving
Scaling
Translating
Outside
Definition at line 82 of file axlLightsWidget.h.
Constructor & Destructor Documentation
axlLightsWidget::axlLightsWidget ( )
protected
Definition at line 105 of file axlLightsWidget.cpp.
axlLightsWidget::~axlLightsWidget ( void  )
protected
Definition at line 135 of file axlLightsWidget.cpp.
Member Function Documentation
void axlLightsWidget::CreateDefaultProperties ( void  )
protected
Definition at line 624 of file axlLightsWidget.cpp.
int axlLightsWidget::HighlightHandle ( vtkProp *  prop)
protected
Definition at line 315 of file axlLightsWidget.cpp.
void axlLightsWidget::initializePoints ( void  )
Definition at line 147 of file axlLightsWidget.cpp.
vtkActor* axlLightsWidget::netActor ( void  )
static axlLightsWidget* axlLightsWidget::New ( )
static
void axlLightsWidget::OnLeftButtonDown ( void  )
protectedvirtual
Definition at line 403 of file axlLightsWidget.cpp.
void axlLightsWidget::OnLeftButtonUp ( void  )
protectedvirtual
Definition at line 453 of file axlLightsWidget.cpp.
void axlLightsWidget::OnMouseMove ( void  )
protectedvirtual
Definition at line 497 of file axlLightsWidget.cpp.
void axlLightsWidget::PlaceWidget ( double  bounds[6])
Definition at line 374 of file axlLightsWidget.cpp.
void axlLightsWidget::PlaceWidget ( void  )
inline
Definition at line 54 of file axlLightsWidget.h.
void axlLightsWidget::PlaceWidget ( double  xmin,
double  xmax,
double  ymin,
double  ymax,
double  zmin,
double  zmax
inline
Definition at line 57 of file axlLightsWidget.h.
void axlLightsWidget::PrintSelf ( ostream &  os,
vtkIndent  indent
Definition at line 391 of file axlLightsWidget.cpp.
void axlLightsWidget::ProcessEvents ( vtkObject *  object,
void *  clientdata,
void *  calldata
staticprotected
Definition at line 355 of file axlLightsWidget.cpp.
vtkActorCollection * axlLightsWidget::ptsActors ( void  )
Definition at line 223 of file axlLightsWidget.cpp.
void axlLightsWidget::resetProperty ( void  )
Definition at line 216 of file axlLightsWidget.cpp.
void axlLightsWidget::SetEnabled ( int  enabling)
Definition at line 228 of file axlLightsWidget.cpp.
void axlLightsWidget::setView ( axlAbstractView view)
Definition at line 142 of file axlLightsWidget.cpp.
void axlLightsWidget::update ( void  )
Definition at line 586 of file axlLightsWidget.cpp.
axlLightsWidget::vtkTypeMacro ( axlLightsWidget  ,
vtk3DWidget
Member Data Documentation
int axlLightsWidget::State
protected
Definition at line 80 of file axlLightsWidget.h.
The documentation for this class was generated from the following files:
