Developer documentation | Axl-2.5.1
axlInteractorStyleRubberBandPick Class Reference
#include <axlInteractorStyleRubberBandPick.h>
Inheritance diagram for axlInteractorStyleRubberBandPick:
Signals
void IdsSelectedChanged (void)
Public Member Functions
 vtkTypeMacro (axlInteractorStyleRubberBandPick, vtkInteractorStyleRubberBandPick)
 axlInteractorStyleRubberBandPick (QObject *parent=0)
 ~axlInteractorStyleRubberBandPick (void)
virtual void OnLeftButtonUp ()
void SetPolyData (vtkSmartPointer< vtkPolyData > points)
QVector< int > ids (void)
Static Public Member Functions
static axlInteractorStyleRubberBandPickNew ()
Detailed Description
Definition at line 34 of file axlInteractorStyleRubberBandPick.h.
Constructor & Destructor Documentation
axlInteractorStyleRubberBandPick::axlInteractorStyleRubberBandPick ( QObject *  parent = 0)
Definition at line 161 of file axlInteractorStyleRubberBandPick.cpp.
axlInteractorStyleRubberBandPick::~axlInteractorStyleRubberBandPick ( void  )
Definition at line 168 of file axlInteractorStyleRubberBandPick.cpp.
Member Function Documentation
QVector< int > axlInteractorStyleRubberBandPick::ids ( void  )
Definition at line 157 of file axlInteractorStyleRubberBandPick.cpp.
void axlInteractorStyleRubberBandPick::IdsSelectedChanged ( void  )
signal
static axlInteractorStyleRubberBandPick* axlInteractorStyleRubberBandPick::New ( )
static
void axlInteractorStyleRubberBandPick::OnLeftButtonUp ( void  )
virtual
Definition at line 70 of file axlInteractorStyleRubberBandPick.cpp.
void axlInteractorStyleRubberBandPick::SetPolyData ( vtkSmartPointer< vtkPolyData >  points)
Definition at line 130 of file axlInteractorStyleRubberBandPick.cpp.
axlInteractorStyleRubberBandPick::vtkTypeMacro ( axlInteractorStyleRubberBandPick  ,
The documentation for this class was generated from the following files:
