#include <axlInspectorObjectSurfaceParametricOffset.h>
| axlInspectorObjectSurfaceParametricOffset::axlInspectorObjectSurfaceParametricOffset |
QWidget * |
parent = 0 | ) |
| axlInspectorObjectSurfaceParametricOffset::~axlInspectorObjectSurfaceParametricOffset |
void |
| void axlInspectorObjectSurfaceParametricOffset::colorChanged |
QColor |
color, |
dtkAbstractData * |
data |
signal |
| void axlInspectorObjectSurfaceParametricOffset::dataChangedByColor |
dtkAbstractData * |
data, |
double |
red, |
double |
green, |
double |
blue |
signal |
| void axlInspectorObjectSurfaceParametricOffset::dataChangedByGeometry |
dtkAbstractData * |
data | ) |
signal |
| void axlInspectorObjectSurfaceParametricOffset::dataChangedByOpacity |
dtkAbstractData * |
data, |
double |
opacity |
signal |
| void axlInspectorObjectSurfaceParametricOffset::dataChangedByShader |
dtkAbstractData * |
data, |
QString |
isophoteShaderXml |
signal |
| void axlInspectorObjectSurfaceParametricOffset::dataChangedBySize |
dtkAbstractData * |
data, |
double |
size |
signal |
| void axlInspectorObjectSurfaceParametricOffset::onColorChanged |
QColor |
color | ) |
slot |
| void axlInspectorObjectSurfaceParametricOffset::onLineEditShaderChanged |
QString |
shader | ) |
slot |
| void axlInspectorObjectSurfaceParametricOffset::onOffsetChanged |
double |
offset | ) |
slot |
| void axlInspectorObjectSurfaceParametricOffset::onOpacityChanged |
int |
opacity | ) |
slot |
| void axlInspectorObjectSurfaceParametricOffset::onShaderChanged |
QString |
shader | ) |
slot |
| void axlInspectorObjectSurfaceParametricOffset::onShaderStateChanged |
bool |
isShader | ) |
slot |
| void axlInspectorObjectSurfaceParametricOffset::onSizeChanged |
int |
size | ) |
slot |
| void axlInspectorObjectSurfaceParametricOffset::openShader |
void |
slot |
| QSize axlInspectorObjectSurfaceParametricOffset::sizeHint |
void |
const |
| void axlInspectorObjectSurfaceParametricOffset::update |
void |
signal |
The documentation for this class was generated from the following files:
