#include <axlInspectorObjectSphere.h>
Definition at line 32 of file axlInspectorObjectSphere.h.
          | axlInspectorObjectSphere::axlInspectorObjectSphere  |
          QWidget *  |
          parent = 0 | ) |
          | axlInspectorObjectSphere::~axlInspectorObjectSphere  |
          void  |
          | void axlInspectorObjectSphere::colorChanged  |
          QColor  |
          color,  |
          dtkAbstractData *  |
          data  |
signal   |
          | void axlInspectorObjectSphere::dataChangedByColor  |
          dtkAbstractData *  |
          data,  |
          double  |
          red,  |
          double  |
          green,  |
          double  |
          blue  |
signal   |
          | void axlInspectorObjectSphere::dataChangedByGeometry  |
          dtkAbstractData *  |
          data | ) |
signal   |
          | void axlInspectorObjectSphere::dataChangedByOpacity  |
          dtkAbstractData *  |
          data,  |
          double  |
          opacity  |
signal   |
          | void axlInspectorObjectSphere::dataChangedByShader  |
          dtkAbstractData *  |
          data,  |
          QString  |
          isophoteShaderXml  |
signal   |
          | void axlInspectorObjectSphere::modifiedProperty  |
          dtkAbstractData *  |
          int  |
signal   |
          | void axlInspectorObjectSphere::onColorChanged  |
          QColor  |
          color | ) |
slot   |
          | void axlInspectorObjectSphere::onCoordDataChanged_x  |
          double  |
          x | ) |
slot   |
          | void axlInspectorObjectSphere::onCoordDataChanged_y  |
          double  |
          y | ) |
slot   |
          | void axlInspectorObjectSphere::onCoordDataChanged_z  |
          double  |
          z | ) |
slot   |
          | void axlInspectorObjectSphere::onLineEditShaderChanged  |
          QString  |
          shader | ) |
slot   |
          | void axlInspectorObjectSphere::onOpacityChanged  |
          int  |
          opacity | ) |
slot   |
          | void axlInspectorObjectSphere::onRadiusChanged  |
          double  |
          radius | ) |
slot   |
          | void axlInspectorObjectSphere::onRecievedDataChanged  |
          void  |
slot   |
          | void axlInspectorObjectSphere::onShaderChanged  |
          QString  |
          shader | ) |
slot   |
          | void axlInspectorObjectSphere::onShaderStateChanged  |
          bool  |
          isShader | ) |
slot   |
          | void axlInspectorObjectSphere::openShader  |
          void  |
slot   |
          | void axlInspectorObjectSphere::setData  |
          axlSphere *  |
          point | ) |
slot   |
          | QSize axlInspectorObjectSphere::sizeHint  |
          void  |
           const |
          | void axlInspectorObjectSphere::update  |
          void  |
signal   |
          | void axlInspectorObjectSphere::updateValues  |
          void  |
slot   |
The documentation for this class was generated from the following files:
