#include <axlInspectorObjectSet.h>
Definition at line 31 of file axlInspectorObjectSet.h.
| axlInspectorObjectSet::axlInspectorObjectSet |
QWidget * |
parent = 0 | ) |
| axlInspectorObjectSet::~axlInspectorObjectSet |
void |
| void axlInspectorObjectSet::colorChanged |
QColor |
color, |
dtkAbstractData * |
data |
signal |
| void axlInspectorObjectSet::dataChangedByGeometry |
dtkAbstractData * |
data | ) |
signal |
| void axlInspectorObjectSet::modifiedProperty |
dtkAbstractData * |
int |
signal |
| void axlInspectorObjectSet::onColorChanged |
QColor |
color | ) |
slot |
| void axlInspectorObjectSet::onLineEditShaderChanged |
QString |
shader | ) |
slot |
| void axlInspectorObjectSet::onOpacityChanged |
int |
opacity | ) |
slot |
| void axlInspectorObjectSet::onSamplingDataChanged_u |
int |
numSamples | ) |
slot |
| void axlInspectorObjectSet::onSamplingDataChanged_v |
int |
numSamples | ) |
slot |
| void axlInspectorObjectSet::onShaderChanged |
QString |
shader | ) |
slot |
| void axlInspectorObjectSet::onShaderStateChanged |
bool |
isShader | ) |
slot |
| void axlInspectorObjectSet::onSizeChanged |
int |
size | ) |
slot |
| void axlInspectorObjectSet::openShader |
void |
slot |
| void axlInspectorObjectSet::setData |
QList< dtkAbstractData * > |
dataSet | ) |
slot |
| QSize axlInspectorObjectSet::sizeHint |
void |
const |
| void axlInspectorObjectSet::update |
void |
signal |
The documentation for this class was generated from the following files:
