Developer documentation | Axl-2.5.1
axlInspectorObjectCone Class Reference
#include <axlInspectorObjectCone.h>
Inheritance diagram for axlInspectorObjectCone:
axlInspectorObjectInterface
Public Slots
void setData (axlCone *cone)
void onCoordDataChangedApex_x (double x)
void onCoordDataChangedApex_y (double y)
void onCoordDataChangedApex_z (double z)
void onCoordDataChangedBasePoint_x (double x)
void onCoordDataChangedBasePoint_y (double y)
void onCoordDataChangedBasePoint_z (double z)
void onRadiusChanged (double radius)
void onColorChanged (QColor color)
void onOpacityChanged (int opacity)
void openShader (void)
void onShaderStateChanged (bool isShader)
void onShaderChanged (QString)
void onLineEditShaderChanged (QString)
void updateValues (void)
- Public Slots inherited from axlInspectorObjectInterface
virtual void setData (dtkAbstractData *data)
Public Member Functions
 axlInspectorObjectCone (QWidget *parent=0)
 ~axlInspectorObjectCone (void)
QSize sizeHint (void) const
- Public Member Functions inherited from axlInspectorObjectInterface
 axlInspectorObjectInterface (QWidget *parent=0)
virtual ~axlInspectorObjectInterface (void)
void setObjectFactorySingleton (axlInspectorObjectFactory *objectFactorySingleton)
axlInspectorObjectFactoryobjectFactorySingleton (void)
void initComboBoxShaderValue (QComboBox *comboBoxShader, QLineEdit *lineEditShader)
QString filePath (const QString &shader)
Additional Inherited Members
- Signals inherited from axlInspectorObjectInterface
void dataChangedByGeometry (dtkAbstractData *data)
void showCurrentPoint (double u, double v, dtkAbstractData *data)
void hideCurrentPoint (double u, double v, dtkAbstractData *data)
void moveCurrentPoint (double u, double v, dtkAbstractData *data)
void tubeFilterRadiusChanged (dtkAbstractData *data, double radius)
void updateStateColor (dtkAbstractData *data, int i)
void modifiedProperty (dtkAbstractData *, int)
void update ()
- Protected Attributes inherited from axlInspectorObjectInterface
axlInspectorObjectFactorym_objectFactorySingleton
Detailed Description
Definition at line 32 of file axlInspectorObjectCone.h.
Constructor & Destructor Documentation
axlInspectorObjectCone::axlInspectorObjectCone ( QWidget *  parent = 0)
Definition at line 57 of file axlInspectorObjectCone.cpp.
axlInspectorObjectCone::~axlInspectorObjectCone ( void  )
Definition at line 83 of file axlInspectorObjectCone.cpp.
Member Function Documentation
void axlInspectorObjectCone::onColorChanged ( QColor  color)
slot
Definition at line 242 of file axlInspectorObjectCone.cpp.
void axlInspectorObjectCone::onCoordDataChangedApex_x ( double  x)
slot
Definition at line 193 of file axlInspectorObjectCone.cpp.
void axlInspectorObjectCone::onCoordDataChangedApex_y ( double  y)
slot
Definition at line 200 of file axlInspectorObjectCone.cpp.
void axlInspectorObjectCone::onCoordDataChangedApex_z ( double  z)
slot
Definition at line 207 of file axlInspectorObjectCone.cpp.
void axlInspectorObjectCone::onCoordDataChangedBasePoint_x ( double  x)
slot
Definition at line 214 of file axlInspectorObjectCone.cpp.
void axlInspectorObjectCone::onCoordDataChangedBasePoint_y ( double  y)
slot
Definition at line 221 of file axlInspectorObjectCone.cpp.
void axlInspectorObjectCone::onCoordDataChangedBasePoint_z ( double  z)
slot
Definition at line 228 of file axlInspectorObjectCone.cpp.
void axlInspectorObjectCone::onLineEditShaderChanged ( QString  shader)
slot
Definition at line 130 of file axlInspectorObjectCone.cpp.
void axlInspectorObjectCone::onOpacityChanged ( int  opacity)
slot
Definition at line 256 of file axlInspectorObjectCone.cpp.
void axlInspectorObjectCone::onRadiusChanged ( double  radius)
slot
Definition at line 235 of file axlInspectorObjectCone.cpp.
void axlInspectorObjectCone::onShaderChanged ( QString  shader)
slot
Definition at line 165 of file axlInspectorObjectCone.cpp.
void axlInspectorObjectCone::onShaderStateChanged ( bool  isShader)
slot
Definition at line 174 of file axlInspectorObjectCone.cpp.
void axlInspectorObjectCone::openShader ( void  )
slot
Definition at line 156 of file axlInspectorObjectCone.cpp.
void axlInspectorObjectCone::setData ( axlCone cone)
slot
Definition at line 95 of file axlInspectorObjectCone.cpp.
QSize axlInspectorObjectCone::sizeHint ( void  ) const
Definition at line 90 of file axlInspectorObjectCone.cpp.
void axlInspectorObjectCone::updateValues ( void  )
slot
Definition at line 272 of file axlInspectorObjectCone.cpp.
The documentation for this class was generated from the following files:
