| actorField(void) | axlActorFieldSpatial | virtual |
| axlAbstractActor(axlAbstractActor *parent=0) | axlAbstractActor | |
| axlAbstractActorField() | axlAbstractActorField | |
| axlActorFieldSpatial(void) | axlActorFieldSpatial | |
| colRangeMax(void) | axlActorFieldSpatial | virtual |
| colRangeMin(void) | axlActorFieldSpatial | virtual |
| data(void) | axlActorFieldSpatial | virtual |
| displayAsColor(void) | axlActorFieldSpatial | virtual |
| displayAsGlyph(void) | axlActorFieldSpatial | virtual |
| displayAsHedge(void) | axlActorFieldSpatial | virtual |
| displayAsIso(void) | axlActorFieldSpatial | virtual |
| displayAsNoneScalar(void) | axlActorFieldSpatial | virtual |
| displayAsNoneVector(void) | axlActorFieldSpatial | virtual |
| displayAsStream(void) | axlActorFieldSpatial | virtual |
| field(void) | axlActorFieldSpatial | virtual |
| getState(void) | axlAbstractActor | virtual |
| glyphScale(void) | axlActorFieldSpatial | virtual |
| hide(void) | axlAbstractActor | virtualslot |
| hideCurrentPoint(double u, double v, dtkAbstractData *data) | axlAbstractActor | virtualslot |
| identifier(void) | axlAbstractActor | virtual |
| isoCount(void) | axlActorFieldSpatial | virtual |
| isoRangeMax(void) | axlActorFieldSpatial | virtual |
| isoRangeMin(void) | axlActorFieldSpatial | virtual |
| isShowControlPoints(void) | axlAbstractActor | virtual |
| isVisible(void) | axlAbstractActor | virtual |
| magnitude(void) | axlActorFieldSpatial | virtual |
| maxValue(void) | axlActorFieldSpatial | virtual |
| minValue(void) | axlActorFieldSpatial | virtual |
| moveCurrentPoint(double u, double v, dtkAbstractData *data) | axlAbstractActor | virtualslot |
| New(void) | axlActorFieldSpatial | static |
| onControlPointChanged(void) | axlAbstractActor | virtualslot |
| onIsoRadiusChanged(double radius) | axlActorFieldSpatial | virtual |
| onModeChanged(int state) | axlAbstractActor | virtualslot |
| onRemoved(void) | axlAbstractActor | virtualslot |
| onSamplingChanged(void) | axlAbstractActor | virtualslot |
| onSelectBoundaryEdge(int numEdge, int previous, int n) | axlAbstractActor | virtualslot |
| onTubeFilterRadiusChanged(double radius) | axlAbstractActor | virtualslot |
| onUpdateGeometry(void) | axlActorFieldSpatial | inlineslot |
| onUpdateProperty(void) | axlAbstractActor | virtualslot |
| onUpdateStructure(void) | axlAbstractActor | inlinevirtualslot |
| parent(void) | axlAbstractActor | virtual |
| scalarBar(void) | axlActorFieldSpatial | |
| scalarColorMapper(void) | axlActorFieldSpatial | |
| setActiveFieldKind(void) | axlActorFieldSpatial | virtual |
| setActorField(axlAbstractActor *actor) | axlActorFieldSpatial | virtual |
| setColor(double red, double green, double blue) | axlAbstractActor | virtual |
| setColRangeMax(double max) | axlActorFieldSpatial | virtual |
| setColRangeMin(double min) | axlActorFieldSpatial | virtual |
| setData(dtkAbstractData *field) | axlActorFieldSpatial | virtual |
| setDisplay(bool display) | axlAbstractActor | virtual |
| setGlyphScale(double scale) | axlActorFieldSpatial | virtual |
| setInteractor(void *interactor) | axlActorFieldSpatial | virtual |
| setInterpolation(int interpolation) | axlAbstractActor | virtual |
| setIsoCount(int count) | axlActorFieldSpatial | virtual |
| setIsoRangeMax(double max) | axlActorFieldSpatial | virtual |
| setIsoRangeMin(double min) | axlActorFieldSpatial | virtual |
| setMapperCollorArray(void) | axlAbstractActor | virtual |
| setMode(int state) | axlAbstractActor | virtual |
| setOpacity(double opacity) | axlAbstractActor | virtual |
| setParent(axlAbstractActor *parent) | axlAbstractActor | virtual |
| setShader(QString xmlfile) | axlAbstractActor | virtual |
| setShaderFromString(QString xmlfile) | axlAbstractActor | virtual |
| setSize(double size) | axlAbstractActor | virtual |
| setStreamDirection(int direction) | axlActorFieldSpatial | virtual |
| setStreamPropagation(double propagation) | axlActorFieldSpatial | virtual |
| setStreamRadius(double radius) | axlActorFieldSpatial | virtual |
| setup(void) | axlActorFieldSpatial | |
| show(void) | axlAbstractActor | virtualslot |
| showControlPoints(bool show) | axlAbstractActor | virtual |
| showCurrentPoint(double u, double v, dtkAbstractData *data) | axlAbstractActor | virtualslot |
| stateChanged(dtkAbstractData *data, int mode) | axlAbstractActor | signal |
| streamRadius(void) | axlActorFieldSpatial | virtual |
| toMesh(void) | axlAbstractActor | virtual |
| update(void) | axlActorFieldSpatial | virtual |
| updateArray(void) | axlActorFieldSpatial | |
| updated(void) | axlAbstractActor | signal |
| vtkTypeRevisionMacro(axlActorFieldSpatial, vtkAssembly) | axlActorFieldSpatial | |
| ~axlAbstractActor(void) | axlAbstractActor | virtual |
| ~axlAbstractActorField(void) | axlAbstractActorField | virtual |
| ~axlActorFieldSpatial(void) | axlActorFieldSpatial | |
