Developer documentation | Axl-2.5.1
axlActorFieldDiscreteStreamObserver Class Reference
Inheritance diagram for axlActorFieldDiscreteStreamObserver:
Public Member Functions
virtual void Execute (vtkObject *caller, unsigned long event, void *)
Static Public Member Functions
static axlActorFieldDiscreteStreamObserverNew (void)
Public Attributes
vtkSmartPointer< vtkSphereRepresentation > vector_stream_widget_representation
vtkSmartPointer< vtkPolyData > vector_stream_widget_data
vtkSmartPointer< vtkStreamTracer > vector_stream_tracer
Detailed Description
Definition at line 65 of file axlActorFieldDiscrete.cpp.
Member Function Documentation
virtual void axlActorFieldDiscreteStreamObserver::Execute ( vtkObject *  caller,
void *
inlinevirtual
Definition at line 73 of file axlActorFieldDiscrete.cpp.
static axlActorFieldDiscreteStreamObserver* axlActorFieldDiscreteStreamObserver::New ( void  )
inlinestatic
Definition at line 68 of file axlActorFieldDiscrete.cpp.
Member Data Documentation
vtkSmartPointer<vtkStreamTracer> axlActorFieldDiscreteStreamObserver::vector_stream_tracer
Definition at line 89 of file axlActorFieldDiscrete.cpp.
vtkSmartPointer<vtkPolyData> axlActorFieldDiscreteStreamObserver::vector_stream_widget_data
Definition at line 88 of file axlActorFieldDiscrete.cpp.
vtkSmartPointer<vtkSphereRepresentation> axlActorFieldDiscreteStreamObserver::vector_stream_widget_representation
Definition at line 87 of file axlActorFieldDiscrete.cpp.
The documentation for this class was generated from the following file:
