| ActorState enum name | axlActor | |
| addToObserver(int idEvent, vtkCommand *observer) | axlActorBSpline | virtual |
| axlAbstractActor(axlAbstractActor *parent=0) | axlAbstractActor | |
| axlActor(void) | axlActor | |
| axlActorBSpline(void) | axlActorBSpline | protected |
| axlActorCurveBSpline(void) | axlActorCurveBSpline | protected |
| data(void) | axlActorCurveBSpline | virtual |
| deleteObserver(void) | axlActor | |
| drawAssymblyMatrix(void) | axlActor | protected |
| edition enum value | axlActor | |
| fields(void) | axlActor | |
| getActor(void) | axlActor | |
| getCellArray(void) | axlActor | |
| getCellPicker() | axlActor | |
| getControlPoints(void) | axlActorBSpline | virtual |
| getCurveMapperInput(void) | axlActorCurveBSpline | |
| getDataSetMapper(void) | axlActor | |
| getInteractor(void) | axlActor | virtual |
| getMapper(void) | axlActor | |
| getNormals(void) | axlActor | |
| getObserver(void) | axlActor | |
| getObserverData(void) | axlActor | |
| getPoints(void) | axlActor | |
| getPolyData(void) | axlActor | |
| getState(void) | axlActor | virtual |
| getUnstructuredGrid(void) | axlActor | |
| getvtkVolume(void) | axlActor | |
| hide(void) | axlActor | virtualslot |
| hideCurrentPoint(double u, double v, dtkAbstractData *data) | axlActorBSpline | virtualslot |
| identifier(void) | axlAbstractActor | virtual |
| initCurrentPoint(void) | axlActorBSpline | virtualslot |
| isShowControlPoints(void) | axlActorBSpline | virtual |
| isVisible(void) | axlActor | virtual |
| meshProcess(void) | axlActorCurveBSpline | |
| moveCurrentPoint(double u, double v, dtkAbstractData *data) | axlActorBSpline | virtualslot |
| New(void) | axlActorCurveBSpline | static |
| NewObserver(void) | axlActor | |
| onControlPointChanged() | axlActorBSpline | virtualslot |
| onModeChanged(int state) | axlActorBSpline | virtualslot |
| onRemoved(void) | axlActorBSpline | virtualslot |
| onSamplingChanged(void) | axlActorCurveBSpline | virtualslot |
| onSelectBoundaryEdge(int numEdge, int previous, int n) | axlAbstractActor | virtualslot |
| onTubeFilterRadiusChanged(double radius) | axlActorCurveBSpline | virtualslot |
| onUpdateGeometry(void) | axlActorCurveBSpline | slot |
| onUpdateProperty(void) | axlAbstractActor | virtualslot |
| onUpdateStructure(void) | axlActorBSpline | inlinevirtual |
| parent(void) | axlAbstractActor | virtual |
| passive enum value | axlActor | |
| pointsUpdate(void) | axlActorCurveBSpline | |
| polyDataUpdate(void) | axlActorCurveBSpline | |
| selection enum value | axlActor | |
| setActor(vtkSmartPointer< vtkActor > actor) | axlActor | |
| setCellArray(vtkSmartPointer< vtkCellArray > cellArray) | axlActor | |
| setCellPicker(vtkSmartPointer< vtkCellPicker > cellPicker) | axlActor | |
| setColor(double red, double green, double blue) | axlActor | virtual |
| setControlPoints(axlControlPointsWidget *controlPoints) | axlActorBSpline | virtual |
| setControlPolygon(bool control) | axlActorBSpline | virtual |
| setData(dtkAbstractData *spline_curve1) | axlActorCurveBSpline | virtual |
| setDataSetMapper(vtkSmartPointer< vtkDataSetMapper > mapper) | axlActor | |
| setDisplay(bool display) | axlActorBSpline | virtual |
| setInteractor(void *interactor) | axlActor | virtual |
| setInterpolation(int interpolation) | axlActor | virtual |
| setMapper(vtkSmartPointer< vtkPolyDataMapper > mapper) | axlActor | |
| setMapperCollorArray(void) | axlAbstractActor | virtual |
| setMode(int state) | axlActorBSpline | virtual |
| setNormals(vtkSmartPointer< vtkDoubleArray > normals) | axlActor | |
| setObserver(axlActorControlPolygonObserver *observer) | axlActor | |
| setObserverData(dtkAbstractData *data) | axlActor | |
| setOpacity(double opacity) | axlActor | virtual |
| setParent(axlAbstractActor *parent) | axlAbstractActor | virtual |
| setPoints(vtkSmartPointer< vtkPoints > points) | axlActor | |
| setPolyData(vtkSmartPointer< vtkPolyData > polyData) | axlActor | |
| setShader(QString vsfile) | axlActor | virtual |
| setShaderFromString(QString vertex_shader_source, QString fragment_shader_source) | axlActor | virtual |
| axlAbstractActor::setShaderFromString(QString xmlfile) | axlAbstractActor | virtual |
| setSize(double size) | axlActor | virtual |
| setState(int state) | axlActor | virtual |
| setUnstructuredGrid(vtkSmartPointer< vtkUnstructuredGrid > unstructuredGrid) | axlActor | |
| setvtkVolume(vtkSmartPointer< vtkVolume > actor) | axlActor | |
| show(void) | axlActor | virtualslot |
| showControlPoints(bool show) | axlActorBSpline | virtual |
| showCurrentPoint(double u, double v, dtkAbstractData *data) | axlActorBSpline | virtualslot |
| stateChanged(dtkAbstractData *data, int mode) | axlAbstractActor | signal |
| toMesh(void) | axlAbstractActor | virtual |
| update(void) | axlActor | virtualslot |
| updated(void) | axlAbstractActor | signal |
| vtkTypeRevisionMacro(axlActorCurveBSpline, vtkAssembly) | axlActorCurveBSpline | |
| ~axlAbstractActor(void) | axlAbstractActor | virtual |
| ~axlActor(void) | axlActor | |
| ~axlActorBSpline(void) | axlActorBSpline | protected |
| ~axlActorCurveBSpline(void) | axlActorCurveBSpline | protected |
