addField(axlAbstractField *field) | axlAbstractData | |
axlAbstractData(axlAbstractData *parent=NULL) | axlAbstractData | |
axlAbstractData(const axlAbstractData &data) | axlAbstractData | |
axlAbstractVolume(void) | axlAbstractVolume | |
axlAbstractVolumeBSpline(void) | axlAbstractVolumeBSpline | |
axlAbstractVolumeNurbs(void) | axlAbstractVolumeNurbs | |
axlAbstractVolumeParametric(void) | axlAbstractVolumeParametric | |
changeFieldName(QString fieldName) | axlAbstractData | |
color | axlAbstractData | |
color(void) const | axlAbstractData | |
connectionsAreDefined(void) | axlAbstractVolumeBSpline | virtual |
convertDataToQVariant(void) const | axlAbstractVolumeBSpline | virtual |
convertQVariantToData(const QVariantList &data) | axlAbstractVolumeBSpline | virtual |
copy(void) const | axlAbstractVolumeBSpline | virtual |
countControlPoints(void) const | axlAbstractVolumeBSpline | virtual |
countControlPoints_u(void) const | axlAbstractVolumeBSpline | virtual |
countControlPoints_v(void) const | axlAbstractVolumeBSpline | virtual |
countControlPoints_w(void) const | axlAbstractVolumeBSpline | virtual |
defineControlPointConnection(int i, int j) | axlAbstractVolumeBSpline | virtual |
description(void) const | axlAbstractVolumeBSpline | virtual |
dimension(void) const | axlAbstractVolume | virtual |
editable(void) | axlAbstractData | |
endParam_u(void) | axlAbstractVolumeParametric | virtual |
endParam_v(void) | axlAbstractVolumeParametric | virtual |
endParam_w(void) | axlAbstractVolumeParametric | virtual |
eval(double u, double v, double w) | axlAbstractVolumeParametric | virtual |
eval(axlPoint *point, double u, double v, double w) | axlAbstractVolumeParametric | virtual |
eval(double &, double &, double &, double u, double v, double w) | axlAbstractVolumeParametric | virtual |
eval(double u, double v, double w, int derivs, bool u_from_right=true, bool v_from_right=true, bool w_from_right=true, double resolution=1.0e-12) | axlAbstractVolumeParametric | virtual |
eval2(double u, double v, double w) | axlAbstractVolumeParametric | virtual |
fields(void) | axlAbstractData | |
getCoef(int n, int m, int k) const | axlAbstractVolumeBSpline | virtual |
getCoef(int n) const | axlAbstractVolumeBSpline | virtual |
getControlPointConnection(int i) | axlAbstractVolumeBSpline | virtual |
getCoord(int n, int m, int k, int v) const | axlAbstractVolumeBSpline | virtual |
getKnot_u(int n) const | axlAbstractVolumeBSpline | virtual |
getKnot_v(int n) const | axlAbstractVolumeBSpline | virtual |
getKnot_w(int n) const | axlAbstractVolumeBSpline | virtual |
getWeight(int n, int m, int k) const | axlAbstractVolumeBSpline | virtual |
gridEvaluator(int num_u, int num_v, int num_w, std::vector< double > &points, std::vector< double > ¶m_u, std::vector< double > ¶m_v, std::vector< double > ¶m_w) | axlAbstractVolumeBSpline | virtual |
indexSelected(int) | axlAbstractVolumeBSpline | signal |
insertKnot_u(double k) | axlAbstractVolumeBSpline | virtual |
insertKnot_v(double k) | axlAbstractVolumeBSpline | virtual |
insertKnot_w(double k) | axlAbstractVolumeBSpline | virtual |
knotVectorSize_u(void) const | axlAbstractVolumeBSpline | virtual |
knotVectorSize_v(void) const | axlAbstractVolumeBSpline | virtual |
knotVectorSize_w(void) const | axlAbstractVolumeBSpline | virtual |
mesh(void) | axlAbstractData | |
modifiedField(void) | axlAbstractData | signal |
modifiedGeometry(void) | axlAbstractData | signal |
modifiedProperty(void) | axlAbstractData | signal |
modifiedStructure(void) | axlAbstractData | signal |
normal(axlPoint *normal, double u, double v, double w) | axlAbstractVolumeParametric | virtual |
normal(double u, double v, double w) | axlAbstractVolumeParametric | virtual |
normal(dtkDeprecated::dtkVector3D< double > *normal, double u, double v, double w) | axlAbstractVolumeParametric | virtual |
numSamples_u(void) | axlAbstractVolumeParametric | virtual |
numSamples_v(void) | axlAbstractVolumeParametric | virtual |
numSamples_w(void) | axlAbstractVolumeParametric | virtual |
opacity | axlAbstractData | |
opacity(void) const | axlAbstractData | |
order_u(void) const | axlAbstractVolumeBSpline | virtual |
order_v(void) const | axlAbstractVolumeBSpline | virtual |
order_w(void) const | axlAbstractVolumeBSpline | virtual |
printCoeffs(bool print) const | axlAbstractVolumeBSpline | virtual |
printKnotsVector(bool print) const | axlAbstractVolumeBSpline | virtual |
rational(void) const | axlAbstractVolumeBSpline | virtual |
removeKnot_u(double k) | axlAbstractVolumeBSpline | virtual |
removeKnot_v(double k) | axlAbstractVolumeBSpline | virtual |
removeKnot_w(double k) | axlAbstractVolumeBSpline | virtual |
resetControlPointConnections(void) | axlAbstractVolumeBSpline | virtual |
samples_u | axlAbstractVolumeParametric | |
samples_u(void) const | axlAbstractVolumeParametric | |
samples_v | axlAbstractVolumeParametric | |
samples_v(void) const | axlAbstractVolumeParametric | |
samples_w | axlAbstractVolumeParametric | |
samples_w(void) const | axlAbstractVolumeParametric | |
sampling() | axlAbstractVolumeBSpline | virtual |
samplingChanged(void) | axlAbstractVolumeBSpline | signal |
scalarValue(double u, double v, double w) | axlAbstractVolumeBSpline | |
selectIndex(int i) | axlAbstractVolumeBSpline | inlinevirtual |
setCoef(int n, int m, int k, int v, double c) | axlAbstractVolumeBSpline | virtual |
setCoef(int n, int m, int k, double *controlPoint) | axlAbstractVolumeBSpline | virtual |
setCoef(int n, double *controlPoint) | axlAbstractVolumeBSpline | virtual |
setColor(double r, double g, double b) | axlAbstractData | |
setColor(const QColor &color) | axlAbstractData | slot |
setEditable(bool edit) | axlAbstractData | slot |
setMesh(axlMesh *mesh) | axlAbstractData | |
setNumSamples_u(int numSamples) | axlAbstractVolumeParametric | virtual |
setNumSamples_v(int numSamples) | axlAbstractVolumeParametric | virtual |
setNumSamples_w(int numSamples) | axlAbstractVolumeParametric | virtual |
setOpacity(const double &opacity) | axlAbstractData | slot |
setSamples_u(const int &color) | axlAbstractVolumeParametric | slot |
setSamples_v(const int &color) | axlAbstractVolumeParametric | slot |
setSamples_w(const int &color) | axlAbstractVolumeParametric | slot |
setScalarValue(double u, double v, double w, double value) | axlAbstractVolumeBSpline | |
setShader(const QString &shader) | axlAbstractData | slot |
setSize(const double &size) | axlAbstractData | slot |
setStripes(int stripes) | axlAbstractVolumeParametric | virtual |
setUpdateView(bool updateView) | axlAbstractData | |
setVolume(int pointsCount_u, int pointsCount_v, int pointsCount_w, int order_u, int order_v, int order_w, int dimension, double *knots_u, double *knots_v, double *knots_w, double *points, bool rational) | axlAbstractVolumeBSpline | virtual |
shader | axlAbstractData | |
shader(void) const | axlAbstractData | |
size | axlAbstractData | |
size(void) const | axlAbstractData | |
startParam_u(void) | axlAbstractVolumeParametric | virtual |
startParam_v(void) | axlAbstractVolumeParametric | virtual |
startParam_w(void) | axlAbstractVolumeParametric | virtual |
stripes(void) | axlAbstractVolumeParametric | virtual |
toAxlMesh(void) | axlAbstractVolume | virtual |
touchField(void) | axlAbstractData | virtualslot |
touchGeometry(void) | axlAbstractData | slot |
touchProperty(void) | axlAbstractData | slot |
touchStructure(void) | axlAbstractData | slot |
updated(void) | axlAbstractVolumeBSpline | signal |
updateFieldList(QString nameField) | axlAbstractData | |
updateRcoeff() | axlAbstractVolumeBSpline | virtual |
updateView(void) | axlAbstractData | |
volume(void) | axlAbstractVolume | virtual |
~axlAbstractData(void) | axlAbstractData | virtual |
~axlAbstractVolume(void) | axlAbstractVolume | virtual |
~axlAbstractVolumeBSpline(void) | axlAbstractVolumeBSpline | virtual |
~axlAbstractVolumeNurbs(void) | axlAbstractVolumeNurbs | virtual |
~axlAbstractVolumeParametric(void) | axlAbstractVolumeParametric | virtual |
