Class axlAbstractVisitorParametric defines an API for Visitor (design pattern) for axel parametric object. More...
#include <axlAbstractVisitorParametric.h>
Public Member Functions | |
axlAbstractVisitorParametric (QObject *parent=NULL) | |
virtual | ~axlAbstractVisitorParametric (void) |
virtual axlPoint | eval (double u) |
Return a dialog. More... | |
virtual axlPoint | eval (double u, double v) |
Return an axlPoint which contains the evaluation value for parameters (u,v). More... | |
virtual axlPoint | eval (double u, double v, double w) |
Return an axlPoint which contains the evaluation value for parameters (u,v, w). More... | |
Public Member Functions inherited from axlAbstractVisitor | |
axlAbstractVisitor (QObject *parent=NULL) | |
virtual | ~axlAbstractVisitor (void) |
Every axel Visitor for parametric object must inherite from this abstract class.
Definition at line 28 of file axlAbstractVisitorParametric.h.
axlAbstractVisitorParametric::axlAbstractVisitorParametric | ( | QObject * | parent = NULL | ) |
Definition at line 25 of file axlAbstractVisitorParametric.cpp.
virtual |
Definition at line 30 of file axlAbstractVisitorParametric.cpp.
virtual |
Return a dialog.
Return an axlPoint which contains the evaluation value for parameter u.
Definition at line 51 of file axlAbstractVisitorParametric.cpp.
virtual |
Definition at line 62 of file axlAbstractVisitorParametric.cpp.
virtual |
Definition at line 73 of file axlAbstractVisitorParametric.cpp.
