48     qDebug()<<
"axlInspectorObjectInterface::setData : Default implementation";
   60         QDir dirShader(
":axlShader/shader/");
   61         dirShader.setFilter(QDir::Files | QDir::Hidden | QDir::NoSymLinks);
   63         dirShader.setNameFilters(filters);
   65         QFileInfoList list = dirShader.entryInfoList();
   70         QSettings settings(
"inria",
"dtk");
   72         settings.beginGroup(
"shader");
   73         QString defaultPathShader = settings.value(
"path", defaultPath).toString();
   74         defaultPathShader.append(
   76         QDir defaultDirShader(defaultPathShader);
   77         defaultDirShader.setNameFilters(filters);
   78         QFileInfoList list2 = defaultDirShader.entryInfoList();
   84         for (
int i = 0; i < list.size(); ++i) {
   85             if(!items.contains(list.at(i).fileName()))
   86                 items << list.at(i).fileName();
   90         int indInitShader = -1;
   91         int indCurrentShader = -1;
   93         foreach(QString item, items) {
   95             comboBoxShader->addItem(item);
   97             QFileInfo currentFileInfo(lineEditShader->text());
   99             if(currentFileInfo.exists())
  101                 if(item == currentFileInfo.fileName())
  102                     indInitShader =indCurrentShader;
  107         if(indInitShader != -1)
  108             comboBoxShader->setCurrentIndex(indInitShader);
  117     QDir dirShader(
  118     dirShader.setFilter(QDir::Files | QDir::Hidden | QDir::NoSymLinks);
  120     QFileInfo currentFile(dirShader, shader);
  121     if(!currentFile.exists())
  123         QSettings settings(
"inria",
"dtk");
  125         settings.beginGroup(
"shader");
  126         QString defaultPathShader = settings.value(
  127         defaultPathShader.append(
  129         QDir defaultDirShader(defaultPathShader);
  130         currentFile = QFileInfo(defaultDirShader, shader);
  133     return currentFile.absoluteFilePath();
  140 class axlInspectorObjectFactoryPrivate
  156     if(!d->creators.contains(interface_name))
  157         d->creators.insert(interface_name, func);
  164     if(!d->creators.contains(interface_name))
  167     return d->creators[interface_name]();
  172 axlInspectorObjectFactory::axlInspectorObjectFactory(
void) : QObject(), d(new axlInspectorObjectFactoryPrivate)
  177 axlInspectorObjectFactory::~axlInspectorObjectFactory(
void)
bool registerInspectorObject(const QString &interface_name, axlInspectorObjectCreator func)
axlInspectorObjectInterface * create(const QString &interface_name)
bool caseInsensitiveLessThan(const QString &s1, const QString &s2)
virtual ~axlInspectorObjectInterface(void)
static axlInspectorObjectFactory * instance(void)
virtual void setData(dtkAbstractData *data)
void setObjectFactorySingleton(axlInspectorObjectFactory *objectFactorySingleton)
static axlInspectorObjectFactory * s_instance
axlInspectorObjectInterface(QWidget *parent=0)
QHash< QString, axlInspectorObjectCreator > axlInspectorObjectCreatorHash
void initComboBoxShaderValue(QComboBox *comboBoxShader, QLineEdit *lineEditShader)
axlInspectorObjectFactory * objectFactorySingleton(void)
axlInspectorObjectFactory * m_objectFactorySingleton
QString filePath(const QString &shader)
