22 #include <dtkCoreSupport/dtkGlobal.h>
   23 #include <QtCore/qmap.h>
   27 class axlAbstractVolumeBSplinePrivate
   30     QMap<axlPoint, double> scalar_values;
   31     QHash<int, QList<int> >connect;
   47     DTK_DEFAULT_IMPLEMENTATION;
   53     DTK_DEFAULT_IMPLEMENTATION;
   59     DTK_DEFAULT_IMPLEMENTATION;
   65     DTK_DEFAULT_IMPLEMENTATION;
   71     DTK_DEFAULT_IMPLEMENTATION;
   78     DTK_DEFAULT_IMPLEMENTATION;
   84     DTK_DEFAULT_IMPLEMENTATION;
   90     DTK_DEFAULT_IMPLEMENTATION;
   97     DTK_DEFAULT_IMPLEMENTATION;
  103     DTK_DEFAULT_IMPLEMENTATION;
  109     DTK_DEFAULT_IMPLEMENTATION;
  116     DTK_DEFAULT_IMPLEMENTATION;
  122     DTK_DEFAULT_IMPLEMENTATION;
  127     DTK_DEFAULT_IMPLEMENTATION;
  133     DTK_DEFAULT_IMPLEMENTATION;
  139     DTK_DEFAULT_IMPLEMENTATION;
  146     DTK_DEFAULT_IMPLEMENTATION;
  152     DTK_DEFAULT_IMPLEMENTATION;
  158     DTK_DEFAULT_IMPLEMENTATION;
  164     DTK_DEFAULT_IMPLEMENTATION;
  170     DTK_DEFAULT_IMPLEMENTATION;
  176     DTK_DEFAULT_IMPLEMENTATION;
  182     DTK_DEFAULT_IMPLEMENTATION;
  189     DTK_DEFAULT_IMPLEMENTATION;
  190     QVector<axlPoint *> qVect;
  196     DTK_DEFAULT_IMPLEMENTATION;
  199 void axlAbstractVolumeBSpline::setVolume(
int pointsCount_u,
int pointsCount_v,
int pointsCount_w,
int order_u,
int order_v,
int order_w,
int dimension,
double *knots_u,
double *knots_v,
double *knots_w,
double *points,
bool rational)
  201     DTK_DEFAULT_IMPLEMENTATION;
  237     DTK_DEFAULT_IMPLEMENTATION;
  243     DTK_DEFAULT_IMPLEMENTATION;
  249     DTK_DEFAULT_IMPLEMENTATION;
  257     return d->scalar_values.value(point);
  265     d->scalar_values.insert(point, value);
  274     return !d->connect.isEmpty();
  292     return d->connect.value(i);
  302         qDebug() <<
"The two indices must be different.";
  304         int mini = std::min(i,j);
  305         int maxi = std::max(i,j);
  307         if(d->connect.keys().contains(mini)){
  308             QList<int> list = d->connect.value(mini);
  310             if(!list.contains(maxi) ){
  312                 d->connect.insert(mini, list);
  317             d->connect.insert(mini,list);
  325     list.append(identifier());
  332     QVariant orderu = QVariant::fromValue(
order_u());
  334     QVariant orderv = QVariant::fromValue(
order_v());
  336     QVariant orderw = QVariant::fromValue(
order_w());
  338     QVariant
dimension = QVariant::fromValue(3);
  339     list.append(dimension);
  341     for(
int i = 0; i < nu.toInt()+
order_u();i++){
  345     for(
int i = 0; i < nv.toInt()+
order_v();i++){
  349     for(
int i = 0; i < nw.toInt()+
order_w();i++){
  353     for(
int i = 0; i < nu.toInt()*nv.toInt()*nw.toInt();i++){
  356     QVariant name = QVariant::fromValue(objectName());
  362     int nu = data.at(1).toInt();
  363     int nv = data.at(2).toInt();
  364     int nw = data.at(3).toInt();
  365     int orderu = data.at(4).toInt();
  366     int orderv = data.at(5).toInt();
  367     int orderw = data.at(6).toInt();
  370     double *knotsU =
new double[nu+orderu];
  371     for(
int i = 0; i < nu+orderu;i++){
  372         knotsU[i] = data.at(i+8).toDouble();
  376     double *knotsV =
new double[nv+orderv];
  377     for(
int i = 0; i < nv+orderv;i++){
  378         knotsV[i] = data.at(i+8 +nu+orderu).toDouble();
  382     double *knotsW =
new double[nw+orderw];
  383     for(
int i = 0; i < nw+orderw;i++){
  384         knotsW[i] = data.at(i+8 +nu+orderu +nv+orderv).toDouble();
  388     int indice = 8 +nu+orderu +nv+orderv +nw+orderw;
  389     double *CP =
new double[3*nu*nv*nw];
  390     for(
int i = 0; i < nu*nv*nw;i++){
  392         list.append(data.at(indice));
  393         list.append(data.at(indice+1));
  394         list.append(data.at(indice+2));
  395         list.append(data.at(indice+3));
  396         list.append(data.at(indice+4));
  400         CP[3*i] = point->
x();
  401         CP[3*i+1] = point->
y();
  402         CP[3*i+2] = point->
z();
  406     setVolume(nu,nv,nw ,orderu,orderv,orderw,dimension,knotsU, knotsV,knotsW,CP,
false);
  407     setObjectName(data.last().toString());
Class axlPoint defines 3D points.
virtual double getKnot_v(int n) const
virtual void removeKnot_u(double k)
virtual int order_u(void) const
virtual int order_v(void) const
int convertQVariantToData(const QVariantList &data)
Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was suc...
virtual int countControlPoints_v(void) const
virtual void insertKnot_v(double k)
double scalarValue(double u, double v, double w)
axlAbstractVolumeBSpline(void)
virtual QString printCoeffs(bool print) const
QVariantList convertDataToQVariant(void) const
Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData...
virtual int order_w(void) const
virtual axlPoint getCoef(int n, int m, int k) const
virtual void insertKnot_w(double k)
virtual int dimension(void) const
virtual void updateRcoeff()
virtual int knotVectorSize_v(void) const
virtual void resetControlPointConnections(void)
Removes all control point connections.
virtual double getWeight(int n, int m, int k) const
virtual void insertKnot_u(double k)
virtual void removeKnot_v(double k)
virtual double getKnot_u(int n) const
void setScalarValue(double u, double v, double w, double value)
virtual int countControlPoints_u(void) const
virtual void gridEvaluator(int num_u, int num_v, int num_w, std::vector< double > &points, std::vector< double > ¶m_u, std::vector< double > ¶m_v, std::vector< double > ¶m_w)
virtual QVector< axlPoint * > sampling()
virtual int knotVectorSize_w(void) const
virtual QString description(void) const
virtual int countControlPoints_w(void) const
virtual int countControlPoints(void) const
virtual void removeKnot_w(double k)
virtual bool rational(void) const
virtual axlAbstractVolumeBSpline * copy(void) const
virtual ~axlAbstractVolumeBSpline(void)
virtual bool connectionsAreDefined(void)
Return true if control points connections were defined by developers. False if there are default conn...
virtual bool setCoef(int n, int m, int k, int v, double c)
void setCoordinates(double x, double y, double z)
Change coordinates of this point.
virtual double getKnot_w(int n) const
virtual void defineControlPointConnection(int i, int j)
Define connection between the ith and the jth coefficient.
virtual double getCoord(int n, int m, int k, int v) const
virtual void setVolume(int pointsCount_u, int pointsCount_v, int pointsCount_w, int order_u, int order_v, int order_w, int dimension, double *knots_u, double *knots_v, double *knots_w, double *points, bool rational)
virtual int knotVectorSize_u(void) const
virtual QString printKnotsVector(bool print) const
virtual QList< int > getControlPointConnection(int i)
The list returned contains all indices of coefficients that are still to be connected to the ith coef...
